• 22.11.2026, 21:34
Pumpkin
Aqua COmputer Flow Sensor Cable
Thursday, September 3rd 2009, 12:12pm
Hi does anyone know what type of connector is used for the above cable that connects to the A.C flow sensor.
I wish to buy one in black as I will be sleeving all my cables in black :)
This post has been edited 3 times, last edit by "Pumpkin" (Sep 3rd 2009, 12:14pm)
Top_Nurse
Friday, September 4th 2009, 10:35am
A simple three wire cable. Which flow meter are you using and what are you hooking it up to?
Pumpkin
Monday, September 7th 2009, 4:28pm
I have the Aquacomputer flow sensor and also the aqua computer cable but the connector on the end of the cable that goes into the aqua computer high flow sensor is white and not your standard size connector (i.e female fan connector head). I wish to buy a black version of the header.
Top_Nurse
Tuesday, September 8th 2009, 12:08pm
Paint it or dye it. That connector can be hard to find in black. However, you might try Allied Electronics or digiKey.
