• 23.11.2026, 00:59
Top_Nurse
Aquaero with 2 wire flow meter?
Tuesday, September 8th 2009, 12:13pm
I am looking to interface a 2 wire flow meter to an Aquaero. My 2 wire flow meter has a + 5 volt input and a RPM sensor wire just like the Aquaero header except it doesn't have a 3rd ground wire. Will the Aquaero sense the pulse without the ground?
Thursday, September 10th 2009, 11:35am
That will not work, all three pins must be connected.
Top_Nurse
Thursday, September 10th 2009, 12:05pm
Have you tried a two wire interface?
Snyxxx
Thursday, September 10th 2009, 3:29pm
I got this to work with a 2-wire Koolance FM-17.
Please see this thread for details.
http://www.realredraider.com/vbulletin/showthread.php?t=8581
Top_Nurse
Thursday, September 10th 2009, 11:01pm
Thanks! That was exactly the info I was looking for. From the pic on the other site I saw that you attached one to the Aquaero ground lead and one to the RPM lead correct? Do you know why the Aquaero has a + 5 volt on pin 2? The reason I'm asking is that the Koolance flow meter you used has a + 5 volt lead and a RPM lead.
Snyxxx
Thursday, September 10th 2009, 11:13pm
To be honest, I simply left the 3-pin fan connector that came with the FM-17 alone and figured it was meant to work like that. I did not know which wire from the flowmeter went to which wire in the plug either and guessed 50/50 chance. It worked and left it alone.
I then later determined that it was only sending impulses and figured it did not really matter in the end. The amplifier board that comes with the FM-17 multiplies the impulses by 10. The impulse value of 197 is correct for this flowmeter with the Aquaero.
More discussion on the wiring here:
http://www.realredraider.com/vbulletin/showthread.php?t=5821
This post has been edited 1 times, last edit by "Snyxxx" (Sep 10th 2009, 11:18pm)
Top_Nurse
Saturday, September 12th 2009, 12:37pm
What exactly does the 5+ volt do on a AC flowmeter? From a post above it appears to work correctly with a Koolance 2 wire flowmeter by using the ground and RPM connections.
Similar threads
