• 23.11.2026, 00:16
Top_Nurse
Standby power question
Friday, September 11th 2009, 12:39am
I believe this is a Shoggy pic IIRC. What I'm wondering is whether I can just run a single wire from the power loom (violet wire) and just pickup a black (negative) wire up on the Aquaero somewhere (probably one of the 4 pin molex connectors)?
Friday, September 11th 2009, 9:26am
Ground is ground is ground is ground :D
It doesn't matter which ground wire you use.
Top_Nurse
Friday, September 11th 2009, 3:11pm
Thanks Shoggy! I took apart a PSU a while ago and noticed that all the black wires were soldered into the same part of the circuit board. Just wasn't sure this was common procedure. :)
