• 10.10.2026, 08:32
> Evil E. <
Best method to hold rubber gaskets in place ?
Monday, October 5th 2009, 7:18pm
Simple question, difficult task :
What's the best way to place and keep large rubber gaskets (also called O-rings) in place, like the ones you can find in GPU blocks, so that you can properly attach the cover plate on the block without the gasket jumping out of its indentation ?
Shoggy : perhaps you can tell us all how it is done at AquaComputer and/or give us some inside hints and tips ? :)
Top_Nurse
Monday, October 5th 2009, 7:41pm
Go buy some liquid glycerin (I used mineral oil). Apply to o-ring and set in groove. Shoggy told me this years ago and a bottle of the stuff will last you a long time.
This post has been edited 1 times, last edit by "Top_Nurse" (Oct 5th 2009, 8:46pm)
ryan123
Monday, October 19th 2009, 1:43pm
great idea...you should adopt it to keep your gaskets in place.
boatman
Monday, October 26th 2009, 12:06pm
thanks for your useful tip
Similar threads
