• 20.11.2026, 09:40
Top_Nurse
One Ambient sensor hooked to Aquaero and Aquastream XT
Tuesday, October 6th 2009, 3:06pm
Can I use one ambient sensor and feed it into the Aquaero and into my Aquastream XT as well? (parallel mode)
Tuesday, October 6th 2009, 6:45pm
In the aquastream XT tabs you can set a sensor which should be transfered via aquabus to the aquaero. The aquaero will show it as sensor no. 6.
> Evil E. <
Wednesday, October 7th 2009, 3:13pm
Shoggy :
What happens if you already have 6 sensors attached to the Aquaero and you attach another (7th) sensor to the AquaStream ? Is the Aquaero capable of handling this extra (7th) sensor or not ?
And how does the Aquaero deal with the extra sensor ?
- does it show up as a 7th sensor (1~6 = Aquaero + 7 = AquaStream, 1 = AquaStream + 2~7 = Aquaero, ...) ?
- does 1 of the 6 Aquaero sensors get replaced by the AquaStream sensor ?
- does the Aquaero only see the 6 Aquaero-attached sensors and disregards the 7th (AquaStream) sensor ?
b0nez
Wednesday, October 7th 2009, 6:40pm
Afaik the AS Sensor will replace the 6th AE Sensor.
:rolleyes:
Wednesday, October 7th 2009, 7:30pm
The sixth sensor of the aquaero will be overwritten if you use the sensor of the aquastream.
Top_Nurse
Thursday, October 8th 2009, 7:09am
Interesting question here:
Can I hookup the Aquastream XT to my Aquaero, through the Aquabus, if I already have two (2) older style Aquastream's connected through the Aquaero-Aquastream ribbon cable bridge?
Also can I hook both the USB cable and Aquabus to the XT? The Aquasuite software appears to allow this but since the help file isn't in English I am not certain of this. What would be the up and down sides to such a connection?
This post has been edited 1 times, last edit by "Top_Nurse" (Oct 8th 2009, 7:11am)
Thursday, October 8th 2009, 12:28pm
More than two aquastream will not work. The aquaero can only handle the aquabus ID 10 and 11 for the pumps.
Of course you can connect aquabus and USB at the same time.
