• 21.11.2026, 10:12
cristian.ticu
HELP...AQUAERO IS CAUSING A BSOD
Monday, October 12th 2009, 10:01pm
HI...I USE AN AQUAERO UNIT AND 2 POWERADJUST UNITS FOR A FEW YEARS NOW,AND UNTIL NOW I'VE NEVER HAD ANY SERIOS ISSUES.I'VE BEEN USING THE AQUAERO WIHT ALL KINDS OF HARDWARE,INTEL,AMD,NFORCE4,NFORCE4SLIX16,N680I,X38,N780I,N790I(USUALLY ASUS MOTHERBOARDS),WITH WIN XP X64,VISTA X64 AND ULTIMATLEY WITH WINDOWS 7 X64.
A WEEK AGO I'VE BEEN INSTALLED AN ALPHACOOL ALPHALCD,AND EVERYTHING WORKED FINE FOR A FEW DAYS.THEN CAME TROUBLE;WHEN I SHUT DOWN MY PC IT DISPLAYS AN ERROR SOMETHING ABOUT USBHUB.SYS AND BEGINS THE CRASH DUMP.
TROUGH ELIMINATION I FOUND OUT THAT THE AQUAERO UNIT IS GUILTY.UNPLUGGING IT RESOLVES THE ISSUE.I'VE UNNINSTALLED THE ALPHALCD,WITH ALL IT'S DRIVERS,I'VE RECCONECTED THE AQUAERO(I THOUGHT THAT SOMEHOW THE ALPHACOOL LCD HAS SOMETHING TO DO WITH IT) AND AGAIN BSOD WHEN I SHUTDOWN OR RESTART.
I'VE TRIED TO REINSTALL THE AQUAERO AND THE AQUASUITE(PREVIOUSLY I'VE DELETED ALL THE REGISTRY ENTRIES FROM AQUASUITE),AND THIS TIME,I SOUGHT SOMETHING ODD.I'VE NEVER SEEN IT BEFORE,WHEN ITHE AQUAERO GET'S DETECTED AND INSTALLED ,THE OS ALSO DETECTS AND INSTALLS SOMETHING CALLED ,,AQUAHUB,, AND A GENERIC USBHUB.IS THIS NORMAL?BECAUSE I NEVER SEEN ANYTHING LIKE THIS BEFORE ,AND I'VE INSTALLED THE AQUAERO(AS HID-COMPLIANT DEVICE) DOZENS OF TIMES BEFORE.WHEN I TRY TO UNINSTALL ONLY THE GENERIC USBHUB ,THE AQUASUITE CRASHES.AND THE PROBLEM WITH THE BSOD ON RESTART OR SHUTDOWN ,STILL REMAINS.
Top_Nurse
Tuesday, October 13th 2009, 9:41pm
Sounds to me like your beta software did a number on you. It has been my experience that Windows does not easily give up software files for USB hardware. I would save what you want, format the hard drive, and reinstall Windows.
Similar threads
