• 13.11.2026, 00:29
scarpetta3
Two aquaero
Thursday, October 22nd 2009, 6:23pm
Hi guys, I understand that two tubemeter cannot be connect to a single aquaero. It's right?
If it is, can i connect to my pc more than 1 aquero? For example 2?
If the answer is "yes", I have 12 temperature sensors, 8 fan channel, two tubemeter 2 flowmeter that i can attach to them, is it right?
Another question: how all this things appear in the aquasuite? How can I manage all the things? Are there another label for each aquaero?
I hope that I explain well my question.
Thanx.
Reagards.
Thursday, October 22nd 2009, 7:26pm
You can connect hundreds of our devices to one PC. Every device will get it's own tab within the aquasuite so you can switch between them.
scarpetta3
Thursday, October 22nd 2009, 9:20pm
Ok.
Only another question, I see in the software a tab that it's label with aquastream, but I don't want to install two aquastream, I want to install a two laing with relative poweradjust.
My question is: in which label tha laing come? the same or another? And wich parameters can I set?
Thank you very much for the answer and congrats for your extremely competitve and complete software/hardware.
b0nez
Friday, October 23rd 2009, 6:48pm
Download the Aquasuite and try the build in testmodus.
:rolleyes:
scarpetta3
Saturday, October 24th 2009, 12:48am
Ok, thnx. Now all it's clear.
Congrats for all. All perfect.
insitu46
Saturday, October 24th 2009, 8:17pm
Gosh, I tried connecting two Aquaeros to one PC several months ago and my recollection is that Aquasuite could only see one of them.
Should I try this again?
Wednesday, October 28th 2009, 12:12pm
That should be normally no problem so you should try it again.
Do both work correctly when you connect them alone?
