• 29.11.2026, 19:29
ktseymour
Aquaero LCD screen flashes?
Friday, December 11th 2009, 10:41pm
I just Installed the Aquaero V 4.0, and the screen won't quit flashing? I'm almost 100% certain I hooked It up right using Shoggy's Instructions from Xtremesystems forums. I hooked up both the Aqua stream and the Aquaero via the USB ports on the board. A short while after I hooked up the Aquaero I can no longer run the software without getting dozens of USB error reports from Aquasuite. Nice hat by the way Shoggy 8)
This post has been edited 1 times, last edit by "ktseymour" (Dec 11th 2009, 10:43pm)
ktseymour
Saturday, December 12th 2009, 6:42pm
Here we go again :pinch:
ktseymour
Monday, December 14th 2009, 12:32am
T..wenty six, ah,ah,ah!!!
I can stay at home and be Ignored. :cursing:
Weihnachts-Shoggy
Tuesday, December 15th 2009, 5:35pm
So the LCD constantly turns on and off?! Never heard of something like that before. Try a reset: shut down the system, press and hold the middle button (set) and start the system. After 2 - 3 seconds you should read a reset message on the LCD. Maybe it helps.
ktseymour
Wednesday, December 16th 2009, 9:14pm
I'll give that a try Shoggy.
ktseymour
Saturday, December 19th 2009, 8:32pm
I wonder If this could be a power Issue also? I'm going to double check everything today as far as connections and different power connections.
If these things and the reset don't resolve this does anyone have any other Ideas what could cause this? Could It be the USB Issue I've read about here?
:P One smiley a post until Christmas. It's not every day we get smileys with Santa hats, or Shoggy's for that matter :D
Okay, that's two. I lied :whistling: Three....
ktseymour
Sunday, December 20th 2009, 6:12am
:thumbsup: Got It working Shoggy.
It was either the reset or the power Issue, maybe both?
Thanks for the help Shoggy
Weihnachts-Shoggy
Monday, December 21st 2009, 10:55pm
Great to hear that it is up and running again :thumbsup:
Top_Nurse
Wednesday, December 23rd 2009, 9:41am
It was the reset that did it. Sometimes these controllers get odd information stored in them. A factory reset clears all the data banks.
ktseymour
Wednesday, December 23rd 2009, 7:44pm
It died TN, It was a bad unit from the get-go.
