• 14.07.2026, 04:58
ktseymour
Another Aquasuite Issue
Sunday, December 20th 2009, 5:30pm
The aquasuite software Is now taking Issue with working with the aquaero.
It says nothing Is connected?
I might have figured It out. You have to configure everything In the aquaero menu? Is this right Shoggy? I took a screen shot so you get a better Idea of what's going on, If It shows up proper :Shttp://s922.photobucket.com/albums/ad63/UberTrooper/
This post has been edited 5 times, last edit by "ktseymour" (Dec 20th 2009, 5:35pm)
ktseymour
Monday, December 21st 2009, 7:49pm
Never mind :sleeping:
This Is a bad unit, I'll have to send It In for repair :cursing:
Weihnachts-Shoggy
Monday, December 21st 2009, 11:02pm
Judging from that "yyyyyyyy" I would say the memory of the aquaero is totally messed up. I would recommend to perform a reset of the device: shut down the system, press and hold the middle button (set) and start the system. After 2 - 3 seconds you should read a reset message on the LCD.
It might be also a problem with the USB communication. If possible try another port on your board or a different cable. You can also use it for testing in another PC so you can check if the aquaero is OK or not.
ktseymour
Tuesday, December 22nd 2009, 1:29am
I did a reset twice. It worked for a little while the first time, but the second time after boot-up the screen went blank, and a short while after that the screen started flickering on and off again. The unit Is completely dead now, wont even accept power any more.
I will have to RMA the unit. The only problem now Is I don't think I have my Invoice anymore?
ktseymour
Tuesday, December 22nd 2009, 1:59am
The coolest thing! Gary from Sidewinder Is sending me an RMA so I don't have to send It all the way to the Shoggster 8o
Thanks for the help Shoggy :thumbup:
