• 22.11.2026, 23:05
drbo
A strange problem with Ati 5970 and aquagratiX for HD 5970 [solved]
Sunday, January 24th 2010, 11:23pm
after two days of happily water-cooling my Sapphire 5970, problems started after a reboot. NO POST! :cursing:
Absolutely nothing.
A few hours on the net, suggested two possible problems, either to hot on some components ... or two cold all together ... ?(
Anyway, put back stock cooler, and guess what. No problems ...
Tried the water-cooler again, NO POST.
So I am clueless. Does anybody else experience similar problems. This is the first time I have trouble when watercooling GPUs, and I have tried some (2900XT, 3870, 4870X2 and 4890)
What is the problem?
Any hints is highly appreciated. Hopefully Catalyst 10.1 will solve the problem.
drbo 8)
EDIT: And I am not alone ...
http://www.xtremesystems.org/forums/showthread.php?t=241616
This post has been edited 7 times, last edit by "drbo" (Jan 25th 2010, 8:10pm)
WS: W10 | Asus Rog Strix X299 | i7-7820X | Asus Rog Strix 1080Ti | Dominator 32GB | Corsair 860AXi | 512GB Samsung EVO 970 |WC: EK-Waterblocks | AC- Monitor and Control | 3x EK-CoolStream PE 480 | LD PC-V8
Gamer:W10 | Asus R4E | i7 3930K | 3x Asus HD 7970 CF | Dominator 16GB| Corsair 1200AXi | 2x120GB I520 Raid0 | WC: EK-Waterblocks | AC- Monitor and Control | 4x Airplex PRO 360 | MM Extended Ascension
Kyle XY
Monday, January 25th 2010, 7:12am
Strange...
You don't have time to have the monitoring of temperatures ?
If the architecture is similar to my HD5870, you don't have to put thermal pads on these CPL components.
In my case, even thermal pads were too thick to be put on memory chips. It was impossible to tighten screws of the waterblock.
Then I have nothing on these CPL, put a thick amount of thermal grease for the memory chips and thermal pads on voltage regulators and it's a complete success.
drbo
Monday, January 25th 2010, 8:08pm
Some hours of google, and it seem that my problems is now solved. Although I must admit that I do not really understand why (as many others)...
But is does seem that the 5970 (from all producers), has a coldbug at +35C, or so many suggest (that makes trouble when WC). YES you read the right number.
With the stock cooler, this is not a problem, since the card becomes hotter than a toaster in secods ... but on water ...
So my solution that works, was a combination of a new driver (found the Catalyst 10.1 RC2) and a custom profile, increasing the lower frequencies from 158 to 300, and the lower mem from 300 to 900. The driver is more stable, and the increase in minimum frequencies makes the card hot enough to boot :D
But the whole issue is strange, and the solution was not very obvious ....
drbo 8)
This post has been edited 1 times, last edit by "drbo" (Jan 25th 2010, 8:09pm)
Similar threads
