• 18.11.2026, 02:32
urbtree
Usb connector missing
Tuesday, June 1st 2010, 3:04pm
high all
i`m a noob to this forum so forgive me any faux pas.
my swiftech pump died the other day but luckily i had a an aqua stream as a back up
ive never set on of these up before so i`m looking for a bit of help.
i bought the pump off ebay so i think some of the parts may be missing
i got an IO plate with it that has a molex connector (have)
it also has the pump connector
but there is a usb header on the board and i`m thinking this has to connect to my mother board so i can controll the pump via software, correct?
now there was no supplied usb cable so i`m thinking i`ll have to make one.
i`m worried about how it connects.
do i make a cable to go from the usb header on the braket to the mobo.
also due to the fact that my last pump failed while i was out for the day i`m very interested in the auto shutdown feature of this pump and would like any info i can
thank in advance for your help on this guys
Tuesday, June 1st 2010, 3:08pm
This is not a USB connector.
Please read this:
Aquastream 3.5 Manual
urbtree
Tuesday, June 1st 2010, 4:50pm
ok so now i know wha its called can you tell me where it would connect to so i can go about either ordering the part or making one
i can connect the pump but it seams to be running slowly and i`d like to use all the features of the pump
Tuesday, June 1st 2010, 7:51pm
This is an old aquastream (non XT!) controller which does not offer any USB communication at all. The only way to use a very small set of controlling options is that you connect it to the aquaero via aquabus (in this case the 10-pin socket).
urbtree
Tuesday, June 1st 2010, 9:40pm
great thatnks for the help guys i`ve read through the destructions and got it working perfectly
hobbes_dmS
Tuesday, June 1st 2010, 9:55pm
pun intended? ;) 8) 8)
This post has been edited 1 times, last edit by "hobbes_dmS" (Jun 1st 2010, 9:58pm)
Similar threads
