• 30.11.2026, 22:32
smee
Fittings
Tuesday, June 22nd 2010, 11:55pm
Hi all,first time posting so please go easy with me.
I hope to be able to use a couple of Aquacomputer blocks for my next build.
Aquacomputer cuplex XT di 478 / 775 Block G1/8 thread,and get the AMD bracket to fit my board
Aquacomputer Twinplex XT di Chipset Cooler G1/8 thread
As i do like the look of these blocks.
I would like to use 1/2" ID 3/4" OD tubing,i see in your shop you do these http://www.aquatuning.co.uk/product_info…kel-plated.html
Which then i hope i can use the above tubing,looking at the chipset block the threads look a bit close to be able to us the fittings for the G1/4 for 1/2" compresion fittings.
If this is not possible could someone give me some advise on what fittings i can use and which size tubing i can use as i would like to stick with compresion fittings if possible.
My Rad,Res and Pump have the G1/4 thread if thats any help.
Thanks for looking,any help and advise would be very much appreciated :thumbsup:
Wednesday, June 23rd 2010, 9:57am
Since we don't offer such adapters I can test it but the cuplex should be no problem here. The distance of the threads is much smaller at the twinplex. Guessing from the photos it might work.
smee
Thursday, June 24th 2010, 10:52am
Thanks for the reply,much appreciated :thumbup:
smee
Wednesday, June 30th 2010, 9:32pm
I am thinking of changing my res setup for my next build and would like to use these.
http://shop.aquacomputer.de/product_info…roducts_id=2035
http://shop.aquacomputer.de/product_info…roducts_id=1267
If someone could help me with a couple of questions it would be very much appreciated :)
1) will the bay and facia fit in my Lian - Li case (343b)
2) would i be able to use the facia upside down as well as the Aquatube so i have the two holes at the top of the res and use one hole for filling
This is what i would like to do with the res and bay,first one has a light blue tint acrylic behind the slates showing the tube
Second one has the slats cut out with some tinted acrylic so you could see the tube again,with this one you can see the tube when there are some LEDS in it
Thanks for looking :thumbsup:
smee
Saturday, July 3rd 2010, 5:37pm
Couple of pics of how the front might look.
With slats and acrylic
Without slats and acrylic
koaschten
Monday, July 5th 2010, 4:19pm
As long as you use the lowest point as outtake from the aquatube, i don't see a reason why it wouldn't work.
Zitat von »Dino«
...lauter spinner ;)
dino
smee
Tuesday, July 6th 2010, 11:23am
Thanks for the reply,much apprecited :thumbsup:
smee
Sunday, August 8th 2010, 9:39pm
Dont know if this is the right place for this,thought i would show you where i am with my next project Acrylin 343b.
Most of the case will have white acrylic
Motherboard and top panel cut
I did cut two more panels but i will be doing two new ones for the rear and front as im changing the rear grill and the front res to a Aquatube
I also attacked the rear with a new peice of alluminium
Done a bit this weekend not much, where i am at the mo
Front test fitting still got to cut out for the grills
Top test fit with grill and bolts
Side panel test fit,got to get a peice cut out for a peice of clear acrylic so it sits flush with the panel
Something like this from my old case a while ago but without the bits on the side
If all goes well this is what i hope the front will look like
This is what im using at the mo my firrst attempt at getting wet,plus i treated myself to a new desk ready for when ive done my next build.
Thanks for looking :)
Ian
Monday, August 9th 2010, 2:41pm
A monster... :D
smee
Monday, August 9th 2010, 4:57pm
Thanks for the reply Shoggy,much appreciated :thumbup:
Was also thinking of using an Aquaero but its a bit out of my price range at the mo,might save up and get one at a later date :(
How it would look with the Aquaero 8)
Thanks for looking :thumbup:
smee
Thursday, August 19th 2010, 7:07pm
I am thinking of getting an Aquaero could someone help a noob out with a few questions please.
I will only be cooling the CPU so to some it might be overkill for what im using it for.
I will be using four fans on my rad,so can i use the four fan channel thingy to keep an eye on the rad.
Also if i was to get a Flow sensor "high flow" G1/4 for aquaero, aquastream XT ultra and poweradjust where would be the best place to fit it and which cables would i need to get.
I will be using the white delrin Aquatube and the aquabay AT Baydream (Einbaurahmen für aquatube) Rev. 1.5.
Any help and advice would be very much appreciated to me the noob :thumbsup:
Thanks for looking and your time.
Ian.
smee
Friday, August 27th 2010, 11:27pm
Sorry for the lack of updates build is a bit slow.
Bits to be painted
Got my grills
These will be painted soon with other bits
I got these grills done to sort of match my res front, i think they turned out really good
Thanks for looking
Ian
smee
Wednesday, September 1st 2010, 8:49pm
Grills fitted :)
Dont look to bad :D
Next to do is get it all painted
Ian
smee
Saturday, September 11th 2010, 8:52pm
Sorry for the lack of updates,build still slow at the mo.
Got some bits and bobs
Ram cooler and some blue LEDS to be fitted then painted white
Couple of nice white LED fans
11 more nice white LED fans
And some fittings
smee
Saturday, September 11th 2010, 8:59pm
Did a bit more today,some pics
Grills and Aquatube
Rad,fans and grills fitted
Where i am at the mo
Not brill not bad but im happy with it
Sappibaer
Saturday, September 11th 2010, 11:20pm
Looks nice :thumbup:
Good Job.
Out of Style, but it's Retro!
smee
Tuesday, September 14th 2010, 1:11am
smee
Saturday, October 16th 2010, 3:08pm
Got my bits back from the coaters,some pics
Build starts tommorow :)
Back soon hopefully
smee
Sunday, October 17th 2010, 4:36pm
Couple more pics of the front :)
smee
Friday, October 22nd 2010, 1:11pm
Still got a couple of things to do then it will be done.
How it looks at the mo
Not the best of pics but im happy how it turned out,could have done a better job on some of the build.
