• 05.10.2026, 16:37
zyklonized
Aquabay LCD display
Friday, July 16th 2010, 11:30pm
Hello..
Just got my Aquabay today,and found out that im missing the serial cable. Do i need a special serial cable to connect the Aquabay,or can i buy it from any local PC store ?
A few more questions about the Aquabay :
1. I see where i connect the serial cable to the Aquabay. but where do i plug it in the computer ?
2. When its plugged in,will it automaticly display for example music i play in winamp,and will it show up in Aquasuite as a unit ?
Sunday, July 18th 2010, 3:55pm
When the cable was not included send an e-mail to us or a private message to me with your order details so we can ship it to you.
Yor computer will need a serial port to be able to connect the aquabay CF. Almost every common mainboard from these days does not have such a port anymore. A few ports still have it internal and you can buy a slot cover with such a port to connect it to the board or you should use an USB to serial adapter.
To get informations onto the LCD you will have to use a program like LCD studio for example or plugins for other programs. Just by connecting the LCD to the PC it won't do anything.
zyklonized
Sunday, July 18th 2010, 11:26pm
Thanks for quick answer...
I bought it used,so its no mistake made by Aquacomputer :)
Think ill let it be for a while,finding it pretty hard setting it up,and using the software etc.
zyklonized
Monday, July 19th 2010, 2:12am
By the way... Do you know if i need a driver or something to get my Aquaero to show up in Aquasuite ? Im using Windows 7 x64.
Tuesday, July 20th 2010, 9:30am
No, you don't need a driver. The aquaeor is programmes as an HI-Device and acts like a mouse or keyboard. It should work without any drivers.
If it does not work you maybe want to try it with another PC to check either it is a problem with the aquaero or the PC.
