• 03.10.2026, 21:39
Brama
Aquaduct 360 XT tubing
Friday, October 1st 2010, 10:46am
Hello, I am interested to buy the system in object but I was not able to find the tubing size, to order the correct G1/4 connectors for waterblocks.
the only data that I found is "plug & cool tube in-and return pipe (length of approx. 2 m each)"
Can someone help me?
Thanks.
Friday, October 1st 2010, 11:59am
The aquaduct has two G1/4 connectors so you can also use any other G1/4 connector. If you want to stay with the plug & cool system you will need a tube with an outer diameter of 8 mm and an inner diameter of 6 mm. It is also very important that the tubing is firm.
An example from our shop:
http://shop.aquacomputer.de/index.php?la…e&cPath=7_39_40
Brama
Tuesday, October 5th 2010, 5:38pm
Many thanks.
Another question: the two tubes supplied with aquaduct 360 xt are for plug&cool connectors (outer diameter 8mm)?
Tuesday, October 5th 2010, 9:57pm
Right, it is plug n cool (8/6mm).
Similar threads
