• 04.10.2026, 05:39
Matt
Need some help with acquaduct 720 xt mark III
Thursday, October 7th 2010, 7:07pm
Hi Shoggy! i'm here again for a small problem with mine Aquacomputer product.
When water temperature go over 28/30 degree, water start to fill out from the plexiglass top ( http://shop.aquacomputer.de/product_info…roducts_id=2471 ), exactly from the 2 holes used to remove the plexiglass cover.
And yes, i've used the rubber protection inside the package ( http://shop.aquacomputer.de/product_info…roducts_id=2003 )
any suggestion would be nice :D
stef13
Thursday, October 7th 2010, 9:03pm
Dear Matt,
Probably the sealing "rubber" is not inside the "trench" .
So, this will do big leakage when the pump increase his speed.
You have to stop, open the cover and place very carfully the seal (it is not easy with big fingers :D ).
after this, place the cover and torque the screw a little at each time (not full torque or you take the risk to put out the seal again).
Check at the end that all screw are well torque.
Good luck and enjoy ,
Steff.
Friday, October 8th 2010, 9:05am
Mount the cover again and tighten the outer screws at first.
