• 30.11.2026, 09:14
lmclaren
Multiple fans on Aquastream XT Ultimate
Tuesday, November 2nd 2010, 5:56am
If I want to run more than 3 fans from the Aquastream (not exceeding 5w total), do you use a 3 wire y cable to all fans? Or do I use 3 wire to fan 1 and 2 wire to fan 2 and 3?
thanks
Lee
creekin
Tuesday, November 2nd 2010, 7:06am
i would say 3 wire just to fan 1 then 2 wire to 2&3,
i asked shoggy a similar q re: 2 pumps on an aquaero as u saw in my thread.
the y splits i get are all 3 pin, i was going to use the same y splits to link 2 asxt's to the aquaero
i have 3 pairs of fans connected to my aquaero via them and it seems to work fine,
i am only getting one rpm number which is correct, so it seems to be showing the average of the 2 rpm signals..
lmclaren
Tuesday, November 2nd 2010, 12:57pm
Thanks Creekin,
I thought the standard was 3 to the first and 2 to the others, Just was wondering if they where doing something different with the Aquastream.
How are you getting on with the repair of your pump? I just brought one, I am a bit nervous now...
BTW, If they send you a board and you need help installing, I am a electronics tech. I am in Hobart.
Lee
creekin
Tuesday, November 2nd 2010, 1:13pm
Still waiting to hear back from AC and retailer, i have posted it back to retailer today but he now says i need to get an RMA first.
I feel this is a manufacturing defect and should be replaced not repaired, as it seems to have 4 different problems.
so fingers crossed. :S
I have no doubts AC will sort the problem the fastest and best way possible. :thumbsup:
I am an electrical tech (concert lighting) i could repair the cable in 5 secs, but not even i can put the magic smoke back in :D
This post has been edited 1 times, last edit by "creekin" (Nov 2nd 2010, 1:18pm)
