• 30.09.2026, 15:19
smoothy
Temps
Saturday, November 20th 2010, 2:01pm
Another thread about temps im afraid.
I have an i7 920 currently overclocked to 4ghz. Idle temps are 45c with load up at 85c. I have two 120x2 rads, with an 4870x2 in the loop also. Do these temps seem right? The water temp idle is around 27c with load at 32c after a couple of hours?
Thanks for any help.
Monday, November 22nd 2010, 2:37pm
Water temperatures looks very good but makes no sense in combination with the CPU temp in my opinion. It should be much lower if your water temperature is that low. Have you checked that the block has proper contact to the CPU?
RcTomcat
Thursday, November 25th 2010, 11:12am
Hey,
i have an i7 920 @ 4,2 Ghz, vcore is above normal ( not sure about the exact voltages )
Idle temps of the processor are 1-2 degrees over water temps with a kryos HF.
@ 27 degrees water temp i get a cpu temp of 53 degrees max after 8 hours of prime 95.
So i would say that your temps are way to high as my load temps are only a few degrees higher than your idle temps.
I suggest that you have a problem with your cpu cooler.
Check if your cpu cooler is mounted correctly, is there enough pressure on the cpu cooler?
Did you use not enough or maybe too much thermal paste?
What about the flow in your system? I get around 95 liters/hour.
This post has been edited 1 times, last edit by "RcTomcat" (Nov 25th 2010, 11:16am)
Similar threads
