• 09.10.2026, 00:20
krypto
aquaero Revision 4 (FW) 417 needs updating
Saturday, November 27th 2010, 3:11pm
Hi everyone,
I been trying to update my firmware from 417 to 442 but cant find a place to download it from and now i really need an update as Fan 2 won't change speed and I'm hoping this will work, iv taken a screenshot to show whats happening also i would like to know how to flash the aquaero 4 as well.
krypto has attached the following image:
Saturday, November 27th 2010, 10:14pm
You don't need to download it because it already comes with your aquasuite ;)
Click on aquaero in the menu bar and select the firmware update function.
krypto
Saturday, November 27th 2010, 10:49pm
Lol can't believe it was that easy i understand why i couldn't find it :wacko:
So I've flashed my aquaero 4 now and all went well but i still have a problem with "fan 2" pins, I've swapped the fans over to make sure it wasn't the fans but it's still the same and runs a full rpm and I'm not sure what i can do? any help would be much appreciated, thanks.
Sunday, November 28th 2010, 1:07am
If it runs at full speed all the time - no matter which settings - it is very likely that the voltage regulator of this channel is damaged. Normally only happens if the load is too high and the temperature gets too hot.
krypto
Sunday, November 28th 2010, 3:28pm
that's what happening, I'm running 3 fans on one is that why its damaged?
Monday, November 29th 2010, 9:49am
As said, very likely that it was damaged by overload/overheat.
krypto
Tuesday, November 30th 2010, 7:28pm
Hi, sorry for late reply just wanted to know if there was anything i can do to repair it?
Weihnachts-Shoggy
Wednesday, December 1st 2010, 9:05am
That voltage regulator must be exchanged (if that is the problem).
Similar threads
