• 13.11.2026, 09:47
gromax
Aquacomputer poweradjust 2 USB
Saturday, December 4th 2010, 9:00pm
Hi!
Im wondering if it is possible to connect one DDC pump and also one fan to a single poweradjust controller (or maybe even split a connection (if necessary) to use even more fans, and how will this then work in the software? Will i be able to contoll them separately?
Also im wondering if there will be any problem with running three poweradjust controllers, each running one Laing DDC (+ one fan per controller if possible) in combo with one Aquastream XT (used in a different loop for GPUs) trough the software? :crazy:
Weihnachts-Shoggy
Saturday, December 4th 2010, 9:05pm
The controller only has one output so you won't see any additional controlling options in the software when you split it. Of course you can use also other things together on one output as long as you are not exceeding the maximum available load.
Using a few controllers together is also no problem. Each device will get its own tab within the aquasuite.
Tomado
Two Poweradjust 2 and Laing D5
Saturday, January 1st 2011, 8:59am
Hello.
My dream is to connect to the Aquaero Laing D5. :crazy:
I know, that it is impossible to make it directly. But is it possible to connection of two Poweradjust 2?
Whether it can work? Could they give in the sum 50 W in this case?
This post has been edited 1 times, last edit by "Tomado" (Jan 2nd 2011, 8:52pm)
Weihnachts-Shoggy
Monday, January 3rd 2011, 10:34am
No, that will not work. When you combine the devices you can not make sure that both use the same voltage output which would cause problems with potential equalization. It is very likely that one controller will die because of this and the other will just follow since it can not handle the load alone.
Tomado
Monday, January 3rd 2011, 7:58pm
Thank You very much for your reply!
