• 07.10.2026, 13:45
Daethis
Will the Aquero 5.0 Do What I Need?
Thursday, February 3rd 2011, 5:25am
I have two MCP-35X pumps that I would attach to Channel 4 using a PWM Splitter. (The MCP-35X have molex power connectors.)
There will be 17 Gentle Typhoon 2150s, and eventually maybe as many as 25 of them. I want to split these into the first three fan connectors. At 12V and current rating I get 1.476 watts each. One channel would need to support 9 fans or 13.284 watts per channel and 1.107 amps. The total amperage would be 3.075 which is below the 5A limit. However the starting current should be 13.25A considering the starting current for each fan is 530 mA. Will this be an issue?
I will also be getting:
tubemeter USB fill level sensor with the aquabus cable to connect it directly to the Aquero 5.0
Multiswitch USB 1.41. If I want to use it to control cold cathodes, I will need to have each cathode connect to its own inverter, and connect each inverters input to a channel of the multiswitch? I can then flash my cathodes to set alarms with the Aquero 5?
Aquaero Power Connect 24pin ATX Standby power / ATX Break This allows the Aquero to shut down due to an alarm, and startup via the remote control?
Temperature sensor internal/external thread G1/4 This allows water temp to be taken to be integrated into the Aquero? It attaches to the sensor connections along with the included four temperature sensors?
Flow sensor "high flow" G1/4 This will measure flow rate of my loop and integrate into Aquero 5.0?
After connecting all these things, I should be able to shut down my PC without regards to what the operating system is or isn't doing. I can cause this shutdown to occur when the water temperature becomes high, if the flow is too low, if my pumps stop giving an rpm signal, if the tube meter says that water is too low?
Can I make channel four adjust voltage based on the flow rate given by the sensor?
Can I make each of the fan channels adjust to different voltages based on the water temperature, and do so independently?
Thanks very much for answering my questions, I'm sorry if there are many of them, I can make it hard to miss one ;) If this will do these things, you've just won a very very happy customer.
Monday, February 7th 2011, 4:24pm
For the fans you definitely need the waterblock. Getting 25 fans running might work but we can not promise it since this equals to almost 160W what you need here to let them spin up. You should also keep in mind that the specifications from the manufacturers are wrong quite often so it is likely that they might even need much more power than that.
It might be a better solution to get some poweramps for the fans.
Right, each cathode must be connected to its inverter and the inverter to the multiswitch. Then you are able to control them trough the aquaero. Please not that when connected to the aquaero the multiswitch can only switch the channels on and off. To dim the cathodes the multiswitch must be connected to USB and controlled with the aquasuite software.
You can use the power connect adapter to switch the PC on and off but since the aquaero also connects to the PC as a regular HID keyboard it is also able to start (depends on BIOS settings) and turn off (depends on windows settings) the PC without additional accessories.
I don't understand your question about the temperature sensors. Every sensor that you connect to the aquaero can be used for monitoring and control.
Every flow sensor that we offer can be used with the aquaero 5 . Of course the high-flow sensor will work too.
If you want a secure shutdown method you will have to use the power connect adapter along with the 3-pin rely plug. The method with the HID keyboard would not work when your system had a crash. You can define a alarm shutdown event for every problem that you can imagine.
Yes, of course you can give every channel its own temperature regulation - also with the same sensor. So you could say that channel 3+4 only start at a temperature above 40°C while the other two channels have a completely different set of values.
Similar threads
