• 05.10.2026, 18:38
kattemad.dk
pumpe fejl
Sunday, February 20th 2011, 11:33pm
Min pumpe køre stadigvæk trods fejl, men i lav hastighed.
jeg har forsøgt at update pumpen mange gange og det er nu lykkes og lys-dioden blinker som den skal. og en anden ting jeg har bemærket er at når jeg ikke tilsluttet usb(MB) til pumpen vil den ikke starte.
Kan nogen evt hjælpe mig
Kattemad.dk
kattemad.dk has attached the following image:
RE: pumpe fejl
Monday, February 21st 2011, 7:51am
translation
Har du prøve en reset af pumpe?
This post has been edited 1 times, last edit by "palme|kex`" (Feb 21st 2011, 7:52am)
Tuesday, February 22nd 2011, 2:26pm
As mentioned in an e-mail from today it is very likely that the surge protection diode on your aquastream XT controller is damaged. That matches perfectly with the weird sensor values that you have.
That diode must be exchanged.
kattemad.dk
Tuesday, April 12th 2011, 5:25pm
My Aqua Stream xt run perfectly after the replacement of the electronics control unit.
Thanks for fast help
:thumbsup:
