• 22.11.2026, 22:39
Phos
Does the aquajet cause water noises?
Thursday, February 24th 2011, 3:28am
Does an upward facing aquajet in an aquatube (that is, the window side facing upwards with the jet in the bottom) cause any audible splashing?
Dr. Shoggy
Thursday, February 24th 2011, 9:54am
Might depend a bit on the flow rate. Normally you should not hear anything from this combination.
Phos
Friday, February 25th 2011, 1:47am
Thanks for the info. What sort of flow rates are they known to be silent with? More specifically, would you expect higher or lower than normal flowrates to cause these sounds?
This post has been edited 2 times, last edit by "Phos" (Feb 25th 2011, 8:06am)
Dr. Shoggy
Friday, February 25th 2011, 9:13am
I would say a higher flow rate might cause it because water will be pushed also into the top and might fall down more "uncontrolled".
Phos
Thursday, April 7th 2011, 2:21am
It seems to me as though the placement I have in mind for the aquatube is going to make all the mounting plates don't look like they'd be ideal, I would either have the side ports pointing in a useless direction (which I suspect I'll need) or I'd have text going in a funny direction. It looks like the aquatube just has 5 equally spaced holes in a circle, so it wouldn't be hard to mount it right to the case if I knew how far away they were from one another. Can you tell me the radius of the circle they form?
Thursday, April 7th 2011, 4:51pm
You can see all dimensions here.
Similar threads
