• 18.11.2026, 15:10
gaspin16
aquaero 5 and pa 2
Saturday, May 7th 2011, 10:58am
Hi, yesterday I finally received the AE 5 XT! One question: I own two PA2, for connecting them to AE5 I use the "high speed" port with a cable. But to be connected in series? ie I have to connect the first PA2 to second and then the second to AE5? I should clarifybetter how it should be this link .. thanks ..
Wednesday, May 11th 2011, 10:33pm
Yes, you can connect the second PA2 to the first one which is connected to the aquaero. But before setting it up this way you have to change the aquabus ID of one PA2 controller and maybe you also have to update the firmware. To do this you connect one of them via USB, run the aquasuite 4.72.00 and update the firmware if the device does not have the latest version. Do this again with the second PA2 controller but this time you also change its aquabus ID from 50 to 51 in the aquasuite. Save the settings to the controller.
Only this way the aquaero can differ between both controllers.
Similar threads
