• 10.10.2026, 13:31
Phatboy69
Fully Loaded Aquaero 5 XT Installation!
Tuesday, May 24th 2011, 4:20pm
What an absolutley amazing product!!!!!!!
Have to say this was the most fun I have had playing with water cooling!!
I have setup "target temp" Curve controls to adjust the various fans based on each loops water temp. Also for the internal air temp, and Fan Amp temps.
I have the RGB led installed replacing the Power led so I get another quick visual clue to whats going on. Green for below operating temp, blue for normal temp and red for overheating.
Im still working out the alarms but for now just have an over temp alarm for each loop and the CPU so it beeps and the RGB led flashes Red.
System Spec
i7 950 @ 4.6Ghz Koolance CPU-370 WB 1.55v - GA-X58A-UD9 EK UD9 WB - 2 x 5870 + 1 x 5970 EK WB @ 1000/1300 1.3v - 1 x 8800Ultra nvidia for physx - 6GB Gskill DDR3-2000 1.66v koolance RAM-35 WB - 4 x Blackice GTX 360 rads w/ 24 x CM R4-L2R-20CK-GP push-pull fans & shrouds - Aquaero 5 XT controller, 6 Poweradjust 2 Ultra controllers - 2 Flow meters - CoolerMaster 1250W PSU - Mountain Mods Extended Ascension Horizon XL-ATX Case - 2 x Koolance 452x2 Res and 4 x D5 pumps - 3 x 24" Acer H243H Eyefinity LCD
Running up on the bench to work out the configuration.
Remounting the waterblock with METAL screws and insulators to tighten up the mount. The included plastic screws felt too flimsy and left the block a little floppy.
Tidying up the cables.
Installed the PA2s with an old Ram fan to cool PA2 heatsinks. Works remarkably well dropping Poweramp temps by 20c! Of course controlled by a PA2, to ramp up with a target temp 70c with a virtual sensor i set up for the PA2 Fan Amp temps
All Assembled
Overview page of my config in Aquasuite 2012.
A couple of the fans generate a dirty RPM signal below 6v but it doesnt effect the operation as the fans are voltage controlled anyway.
Settings screens
Aquaero screenshots
This post has been edited 7 times, last edit by "Phatboy69" (Jul 5th 2011, 2:29pm)
I am Intel of Borg. Resistance is futile. You will be assimilated.
i7 3930K @5Ghz - X79 ASUS Rampage IV Extreme - 4x SLI GTX580 - 16GB DDR3-2000 - 4x GTX 360 rads 24x CM fans - Aquaero 5 XT +6 PA2 Ultras - 2 x Enermax 1500W PSU - MM Extended Ascension Case - 2 x 452x2 Res and 4 x D5 - 3 x 24" Acer H243H LCD
Phatboy69
Tuesday, May 24th 2011, 4:43pm
a good smooth temp control setup going now.
This is a 10 min Kombustor run on the GPUs with a 2 min cool down.
pociej
Tuesday, May 24th 2011, 6:18pm
How did you do that in one area could see more than one indication? (temp, power, etc...)
Phatboy69
Wednesday, May 25th 2011, 2:23am
The extra data is just additional sensor 'values' i inserted for each sensor and then positioned inside the main sensor box.
Phatboy69
Saturday, May 28th 2011, 9:11am
New load testing results with slightly different target temps.
I have 4 GPUs + MB/RAM in a loop - Aquaero 5 calculates 750w dissipation by the loop based on roughly 3c water delta between cold side and hot side of the loop when under load. The loop has 120.6 of rads.
Ambient 23c water idles 30c with fans at 900rpm but under load water goes to 37c with GPUs at 45c and fans at 1800rpm.
Water temp 37c = 42-45c across the GPU cores with 15mins Furmark load.
My target temp for the GPU loop fan controllers is 34c water out.
FYI my GPUs are idling at 950/1300 in 2d and 1000/1300 in 3d. So they dump about 370w at idle into the loop. Because I have eyefinity I have to lock the 2d clocks and voltages to stop flickering.
Before I locked the cards 2d and disabled powersaving mode the water would idle at 1c above ambient.
Here's the test run i just did.
Any comments?
15mins of furmark
5 mins of cooldown
drbo
Saturday, May 28th 2011, 12:47pm
Absolutely a killer build. I am totally jeallous of your rig, especially the casing :love:
Good to see other oldboys enjoying OCing and watercooling.
drbo 8)
WS: W10 | Asus Rog Strix X299 | i7-7820X | Asus Rog Strix 1080Ti | Dominator 32GB | Corsair 860AXi | 512GB Samsung EVO 970 |WC: EK-Waterblocks | AC- Monitor and Control | 3x EK-CoolStream PE 480 | LD PC-V8
Gamer:W10 | Asus R4E | i7 3930K | 3x Asus HD 7970 CF | Dominator 16GB| Corsair 1200AXi | 2x120GB I520 Raid0 | WC: EK-Waterblocks | AC- Monitor and Control | 4x Airplex PRO 360 | MM Extended Ascension
Phatboy69
Sunday, May 29th 2011, 2:49pm
Well its official the A5 will support 2 x D5 pumps running at the minimum pump start voltage of 7v with the pumps on channel 2 & 4 which pushes both channels voltage regulators to 65c with the water block.
I tried channel 3 & 4 together but that triggered over temp of 95c.
Interesting that even a single D5 will heat a fan amp to 65c too but running 2 on channels next to each pushes 95c in both fan amps.
A bit strange because the pumps each only draw 1.4 amps at full power and .8 Amps at 7v which means the heatsink only has to take a load of about .5 amp each channel.
I know the pairs 1&2 3&4 share a temp sensor each pair, so I think the engineers have some tweaking to do in the firmware around temperature measurement of the voltage regulators.
I put a temp probe down the back of the water block heatsink between it and the board and it was registering 40c on the surface of the block and 59c when near a voltage regulator.
Phatboy69
Sunday, May 29th 2011, 3:49pm
I got asked to do a test on another forum and got the following results which might be interesting to some.
3 x 370mA fans at 4.4v drawing 300mA and 2 x D5 pumps at 7v is the safe limit for an A5 with waterblock on my config. Shared 3&4 channels heating to 85c. Adding a 4th fan on the channel pushes it to draw 420mA and right on 95c.
Test Config
Ch1 Waterflow meter 68c
Ch2 1 x D5 running @ 7v 800mA 68c
Ch3 3 x 370mA fans running at 4.4v 300mA 85c
Ch4 1 x D5 running @ 7v 800mA 85c
This means in theory you could run 2 x D5s and 6 x 370mA fans across the other 2 channels. (i have a flow meter on ch1 which you could theoretically put another 3 fans on)
Phatboy69
Tuesday, May 31st 2011, 4:21pm
I did some reconfiguring today.
Ive loaded the 4 D5 pumps onto the controllers and they work a treat!
I have the following config now:
A5
Ch1 PA2 Fans
Ch2 D5-1 GPU Loop
Ch3 Exhaust Fans
Ch4 D5-2 GPU Loop
PA2's
Ch5 CPU Rad1 Fans
Ch6 CPU Rad2 Fans
Ch7 GPU Rad1 Fans
Ch8 GPU Rad2 Fans
Ch9 D5-1 CPU Loop
Ch10 D5-2 CPU Loop
Flowmeter 1 CPU Loop
Flowmeter 8 GPU Loop
Temp Sensors
T15 Ambient Air Temp
T13 Rad Air In Temp
T7 Internal Air Temp
T14 Rad Air Out Temp
T1 CPU Water in
T2 CPU Water out
T3 CPU Water Res out
T4 GPU Water in
T5 GPU Water out
T6 GPU Water Res out
T8 CPU Temp
T16 GPU Temp
Here's a 15min Furmark run with 15min cooldown.
What an amazing piece of technology!
Reallllly quiet for normal computing and light gaming, but an absolute powerhouse when required. All seamlessly controlled.
Phatboy69
Updated Pics Finished Aquaero 5 XT Installation
Sunday, June 12th 2011, 8:09am
I just need to get some Aquacomputer Blue UV additive for the loop to finish the loops and then start buying sleeving stuff to sort the cables.
The left Res is more UV reactant because the loop was running TT UV green and obviously didnt flush as well or maybe even stained the perspex.
McGee-zax
Friday, June 17th 2011, 6:14am
Got mines today... disappointed, the quality of the LCD is very poor... yuck,
viewing angle is a narrow 30 degree at best, definitely made in China.
Currently have the Aquaero 4 VF (plexiglass front & blue tint) and actually think it looks better, I'd
advise those who still own an Aquaero 4 to hold off from upgrading until
they start using better quality screen.
Phatboy69
Friday, June 17th 2011, 7:04am
Its not that bad! Yeah its not the best quality screen you'll see on fan controllers but its a custom made screen specifically for the A5. I doubt you'll see a screen upgrade as it would be cost prohibitive.
They have crammed as many features in as they can and tried to keep the cost down. I think my setup with all my sensors and addon PA2's was around $700 US including shipping so you wont find many people prepared to pay that for monitor and control equipment.
At the end of the day I only spend less than 2mins a day looking at the screen compared to using the Aquasuite 2012 monitoring. When they finish the Aquausuite and built-in samurize type functionality you'll soon not even look at the screen unless your using it for multimedia control. Im happy enough with the quality for what Im using it for anyway.
sparkeyrr
support
Friday, June 17th 2011, 9:01am
How did you get your extra sensors displayed in the overview pages ?I have managed to import the default one but I have a heap of Power adjusts that I cannot see .Would be gr8 if we had some support or info on how to with Aquisuit 2012It is good to see someone implementing a successful build .Mine has been heartache and frustration.I have a aquaro 5 refusing to connect to a multi switch. Connecting and then disappearing. I have a aquaro 5 that randomly reboots when configuring curve controllers.Have some random Power adjust ultra over current faults that are not actually happening. Multi switches that work on one PC’s via usb but refuse to work on another with the same operating system on both pc’s, yet I can communicate with power adjust 2 ultras on both PC’s. Usb driver issues on various Installations where the multi switch Is detected by windows yet fails to install and you get “contact manufacturer for support” blab.I must have just got a lomon 8| 8| :wacko:
Phatboy69
Friday, June 17th 2011, 9:22am
In the left column where the Overview Pages is, see the gear icon in the bottom right of the "Page" view. Click that gear to open setting and then enable edit overview page by ticking the checkbox.
Then go back to your "Page" view and you will see a + sign in the bottom right of the display area. Click that to select the sensor values you want to display. Simple. And then save it as a template in the settings screen with export.
The latest Beta 4 and 1012 firmware might help you with curve controller reboots, though I have never had problems with them, there were some updates to curve controllers and PA2 current settings in the latest 1012 firmware.
Included in the aquasuite the firmware update is 1012 for the fifth aquaero This fixes the following bug in the release of the firmware aquaero 5:
NEW: LCD Hype support
- Errors in the control curve
- Error after standby with the poweradjust
- Lt aquaero now stores all the settings right
- Menu + minor errors in the error surface
NEW: time synchronization tool
In the installation folder there is a aquasuite aquacomputerTimeSync.exe, if that is called, then the time the PC is synchronized to the aquaero.
Theoretically, it is enough if you put a shortcut in the Startup folder. the program closes itself immediately after synchronization
The program synchronizes aquaero aquaero 5 and 4
With the delay parameters: [time] [time] = time in milliseconds, the synchronization is delayed, which can be helpful when in Windows, all is not loaded.
- Corrected temperature measurement of the fan channels
- If a single poweradjust connected to the aquaero 5 was withdrawn and this was in operation, all 10 fans were displayed
- All fans are included in poweradjust settings set to 100%
- Fan alarm menu selection was flawed
- Corrected for Drezahlüberwachung fan 5 to 10 (alarm)
- Boost Start from standby was not executed
- One fan was shown twice in the Logdatenauswahl
- Adapted to current monitoring poweradjust 2
- Alarm processing adapted at startup, adjustable waiting time at startup
- Seitenumschaltzeitbereich of ads has been extended
- Speed ​​measurement of the fan connectors has been improved
- LED brightness of the keys for the inactive set
This post has been edited 1 times, last edit by "Phatboy69" (Jun 17th 2011, 9:26am)
sparkeyrr
Thanks
Saturday, June 18th 2011, 5:41am
Thanks heaps all sorted :thumbsup:
Misteeq
Monday, June 20th 2011, 6:11pm
@ Phatboy69
Maybe an interesting new case for you, the upcoming CaseLabs TX10
Quoted
We are laying out the foundation of the upcoming TX10 (aka “Godzilla”). The intent is to build the best available platform for running a system to the limit for extended periods of time (i.e. folding). It is designed primarily for eVGA SR-2 based system, but could obviously be used for other boards as well. We’ll have a smaller (more reasonable?) HPTX case in the future, but this one is intended for “extreme” applications.
The specs are still pretty fluid, but some features are firm:
HPTX form factor ( supports evga SR-2 )
Two extended length PSU’s
Up to (6) 560 radiators of which four will be a “drop in” design to facilitate assembly
36 Flex-Bays
Overall design will be similar to the M8/M10 but bigger and heavier construction
At the moment the size is about 20"W x 30"D x 36"H, but that is still open to change. Yes, it’s huge but not just for the sake of being big. When you have 4 rads that big (and up to 32 fans or more) proper air circulation becomes an issue not to mention, pumps, reservoirs, and miles of tubing
Misteeq
sparkeyrr
LCD HYP
Tuesday, June 21st 2011, 5:28am
Wondering if anyone has LCD HYP up and running on there new Aquaro 5?Aquaro 5 still a bit unstable rebooting itself intermittentlyFinally got everything working on my build 3 power adjusts 1 Loop , 1 flow Multi switch controlling lighting effects 12 sensors 6 water sensors 6 air zone sensorsAnd about to start on chilling loop .
Phatboy69
Tuesday, June 21st 2011, 5:51am
I did get LCDHype demo apps going but its a pretty steep learning curve to do anything custom. I dont have time to learn the programming language but im sure some others with time on their hands will do some interesting things.
I even got Hype working with my G19 colour keyboard screen and thats where more of my interest lies now. hmmm.. displaying A5 setting on the G19 in colour.. If AC can make it simple to access the data the A5 is storing this is where I'll be spending my time with Hype.
sparkeyrr
aquaro build
Tuesday, June 21st 2011, 9:00am
I also have a G19 keyboard .Could you explain how to get the aquaro overview page on it.
Phatboy69
Tuesday, June 21st 2011, 12:05pm
Sorry what I meant is that I got the demo LCDhype apps running on both the Aquaero 5 LCD and on my G19 screen.
I havent worked out how to get any data out of the A5 database or xml data yet to even attempt putting overview data on the G19 screen. I was making the comment that it will be cool when we have access to the A5 data and be able to use it with LCDhype to create data screens for the G19.
Im hoping some smart little 12 year old script kiddy will work out some cool Hype scripts for the A5 and also hopefully Hype G19 scripts that access xml or A5 database to generate status screens for the G19.
