• 13.10.2026, 09:47
Rustalvl
Geeignet, wenn Chipsatz-Kühler Gigabyte EX58-Serie G1 / 4 bis mein Motherboard ?
Sunday, June 12th 2011, 1:06pm
Komrad Beratung brauchen.
Ist die Mutter desGA-EX58-UD3R (rev. 2.0)
und haben die Möglichkeit, für nicht teuer kaufen
Aquacomputer Aquabridge Chipsatz-Kühler Gigabyte EX58-Serie G1 / 4
Passt es auf mein Motherboard?
P.S. Liszts Kompatibilität mit Mainboards nicht gefunden :-(
schmerzlich Motherboard-Design ähnelt dies und bitten
Verzeihen Sie für schlechtes Deutsch.
Vielen Dank im Voraus. :-)
Komrad need advice.
Is the mother of GA-X58A-UD3R (rev. 2.0)
and have the option to buy for not expensive
AquaComputer Aquabridge Chipsatz-Kuhler Gigabyte EX58-Series G1 / 4
Does it fit on my motherboard?
P.S. Liszt's compatibility with motherboard not found :-(
Forgive for bad English.
Thanks in advance. :-)
This post has been edited 3 times, last edit by "Rustalvl" (Jun 12th 2011, 1:14pm)
Manni24
Sunday, June 12th 2011, 1:39pm
Hi!
According to the compatiblity-tool this Aquabridge fits on your board, it is designed for it. ;)
You can find the tool (in german only) here: http://shop.aquacomputer.de/shop_content.php?coID=11 (the chipset-cooler is the last in the list when you select your mainboard)
The Aquabridge has the part number 23476 which matches the part number in the store you linked.
Manni24
Sunday, June 12th 2011, 1:49pm
oops... :thumbdown:
Your board is "rev 2.0", and i can't find any information if the cooler is designed for rev1 or rev2. Maybe someone else knows more...
gr3if
Sunday, June 12th 2011, 1:50pm
Rustalvl
Sunday, June 12th 2011, 3:14pm
Unfortunately there is generally no information on this water-block.
Posted by appeal to tech support, I will wait for a response yet.
(Leider gibt es in der Regel keine Informationen über dieses Wasser-Block.
Geschrieben von Appell an technischen Support, werde ich auf eine Antwort noch warten.)
