• 04.11.2026, 14:19
Ohms
AE5 defect or fixable?
Tuesday, June 14th 2011, 4:24am
I finally got around to installing my AE5 XT and this is what my screen looked like when I turned it on, the horizontal line straight across my LCD. Is this an actual hardware defect or can this be fixed?
Phatboy69
RE: AE5 defect or fixable?
Tuesday, June 14th 2011, 5:14am
You could try re-seating the daughter board on the back where the pins join the boards together and if that doesnt fix it i would say its RMA time.
You'll obviously need to undo some screws to pull the boards apart to do this.
I am Intel of Borg. Resistance is futile. You will be assimilated.
i7 3930K @5Ghz - X79 ASUS Rampage IV Extreme - 4x SLI GTX580 - 16GB DDR3-2000 - 4x GTX 360 rads 24x CM fans - Aquaero 5 XT +6 PA2 Ultras - 2 x Enermax 1500W PSU - MM Extended Ascension Case - 2 x 452x2 Res and 4 x D5 - 3 x 24" Acer H243H LCD
Ohms
Tuesday, June 14th 2011, 5:24am
I'm really annoyed that I had to wait so long to get it, only to receive what looks like a defective AE5.
Will taking the AE5 apart to re-seat the daughter board void my warranty?
As for having to RMA all I have to say is "UGH" I really don't want to have to ship all the way back to Germany. I wonder if Shoggy can setup a cross shipping or maybe by some miracle convince a US vendor to let me RMA through them even though I didn't purchase it with them. It's a long shot but I one can hope :(
This post has been edited 1 times, last edit by "Ohms" (Jun 14th 2011, 5:26am)
Phatboy69
Tuesday, June 14th 2011, 8:25am
I doubt you will have any problems with warranty, you have to pull the boards apart to mount the water block if you purchase it, so i dont see how they could void the warranty unless you did something really stupid to it.
The guys are pretty good with warranty stuff from what ive seen anyway. Good luck, your only option may be to RMA direct. If you're in Australia there is a vendor called thekoolroom.com based in Melbourne that might help you out if shoggy were to ask???
Ohms
Tuesday, June 14th 2011, 2:52pm
Well that didn't work so I guess I'll have to contact Shoggy.
cristian.ticu
Wednesday, June 15th 2011, 12:13am
had the same problem, they sent me a new screen for free.really good service.wait for the man to reply.
Ohms
Wednesday, June 15th 2011, 1:36pm
Shoggy has already responded to me :) He will be sending me a new screen :thumbup:
