• 07.10.2026, 00:05
sparkeyrr
Aquaro 5 Reboot problem 1012 firmware
Tuesday, June 21st 2011, 11:42am
I have a aquaro 5 connected to 3 power adjust ultras on hi speed aqua bus and 1 multi switch and tube meter connected on low speed aqua bus via y cable all flashed to latest firmware.Intermittently the aquaro 5 reboots .This is very annoying not to mention concerning.I wish to install these aquaro 5 devices into several Hi end server’s but lack the confidence in their robustness at this stage.Is this just a software bug or does my device have issues? ?(
Phatboy69
Tuesday, June 21st 2011, 12:10pm
I doubt its a bug, its more likely a config issue. If the unit encounters conflicts it will reboot. I havent had a reboot yet accept when I had conflicting aquabus IDs on the PA2s or once when I had corrupt data in the A5 after a firmware update.
It seems some of the data structures may change between upgrades and its best to reset everything to defaults after a firmware upgrade. Its a pain but it sorts out the kind of problem your experiencing. Before you reset everything though, just check you dont have any conflicts on the Aquabus.
I am Intel of Borg. Resistance is futile. You will be assimilated.
i7 3930K @5Ghz - X79 ASUS Rampage IV Extreme - 4x SLI GTX580 - 16GB DDR3-2000 - 4x GTX 360 rads 24x CM fans - Aquaero 5 XT +6 PA2 Ultras - 2 x Enermax 1500W PSU - MM Extended Ascension Case - 2 x 452x2 Res and 4 x D5 - 3 x 24" Acer H243H LCD
sparkeyrr
rebooting issue
Wednesday, June 22nd 2011, 5:08am
Ant suggestions on how to fault find this sort of issue?I have addressed ultras 50,51,52,Must admit since Multi switch has been added frequency of reboots seems to have increased a bit.So hard to know whether you have faulty parts or firmware. ?(
Monday, June 27th 2011, 10:27am
The aquabus uses a pretty simple communication protocol without a special error connection. I just guess your problem is based on some communication problems.
sparkeyrr
rebooting problem
Wednesday, June 29th 2011, 7:00am
Problem was caused by cold cathode lighting .When I disconnected rebooting issue stopped
