• 29.11.2026, 13:31
dopax007
Calibration of analog temperature sensors ?
Tuesday, June 28th 2011, 10:21pm
Greetings to all :
I want to know what method uses aquaero 5 with respect to the CALIBRATION of analog temperature sensors with respect to the real temperature . ¿ How do I have to calibrate it ? ¿ what is the most suitable software to monitor such real reference, to make that the most accurate calibration possible?.
Thanks to all
Wednesday, June 29th 2011, 9:19am
you can enter for each sensor a offset value.
dopax007
Wednesday, June 29th 2011, 11:40am
Greetings and many thanks , Sebastian :
Let's see if i have understood correctly ; ¿ something as well as an estimate of
value with regard to the best reference real possible? , Because if so, I repeat
my question ¿ with what software i consulting monitor such reference , the closest to the
real temperature possible?
Thanks, and forgive the, more than likely, my very bad English
Wednesday, June 29th 2011, 12:27pm
The aquaero has an offset option which allows you to change the temperature by max. +/- 6°C.
For example you read out 20°C but the real temperature is 21,5°C, than you would add 1,5°C with the offset function. The offset function is a separate part inside the device so in all overview screens or in the software etc. you will only see the real temperature (21,5°C).
dopax007
Wednesday, June 29th 2011, 4:52pm
Many thanks Shoggy :
I imagined that it would be something like that ; a correction to the estimated value, by the impossibility of placing the probes in the best possible place , with regard to the real value .
For example, in CPU , if i can't put the probe in the best possible site ( below the die by example ) the value that will mark the probe, normally , will be below the real value .
Then , I must try to monitor with Everest , coretemp , Motherboard Monitor , etc....( ¿ what would be better for this task ? ) and try to get as much as possible to the real temperature in order to make that correction estimate ...............¿ what I've understood correctly ?
Greetings
Thursday, June 30th 2011, 1:29pm
Yes, correct.
dopax007
Thursday, June 30th 2011, 3:40pm
many thanks Shoggy
Similar threads
