• 08.10.2026, 19:33
dopax007
¿ Aquaero 5 + T-Balancer BigNG ?
Thursday, June 30th 2011, 5:27pm
Greetings to all :
First and foremost , I ask your forgiveness , if some aspect of my consultation is not entirely appropriate for this forum .
I plan to accomplish , in brief , a major refurbishment of my PC ( based on Win7 64-Bit ) at the level of dissipation, ventilation and control of the same , that is why i bought an Aquaero 5 XT .
The case is that , just a few days , a family gave me a T-Balancer BigNG controller , and started to think about the possibility of taking advantage of the two at the same time ( given that , for the time being , I have no space to increase with the expansions Poweradjust 2 and I need more channels to control the different groups of fans , or simply , having greater control over fans separated ; and also in a future joint use , with regard to liquid cooling ) ; especially if we consider the idea that we can reflect the information of the BigNG on the display of the Aquaero 5 .
In that case, I would like as much information as possible, reflected in the display of the Aquaero 5 .
I think that i can do it with "jaLCD" ( but it seems that is not supported for a long time ) or LCDHype......¿ what is your opinion ? ¿ What would be feasible ?
¿ Is there some other more suitable soft for this task ? ( repeat , based on Win7 64 bits ) .
Friday, July 1st 2011, 12:15pm
The only way is to get the data from the t-balancer exported to a XML file or something like that, import it to LCD Hype ans than send it to the display of the aquaero. A direct communication between both devices is not possible.
dopax007
Friday, July 1st 2011, 11:25pm
Many thanks Shoggy
