• 09.10.2026, 23:23
CyberMarine
tubemeter in aquatube with flush tube
Wednesday, July 6th 2011, 3:21am
The tubemeter manual says that the warranty does not cover the LED if it is submerged in water. Mounted horizontally with a flush tube, this can be hard to avoid. How likely will problems occur in this situation?
Thanks.
Wednesday, July 6th 2011, 1:00pm
Very unlikely but not completely impossible.
CyberMarine
Wednesday, July 6th 2011, 4:29pm
The manual also refers to 2% ACliquid solution. What is ACfluid and is it REALLY needed? Also is the a small or large performance penalty when mounted parallel to the water surface? Manual says it works best when mounted perpendicular to the surface.
Wednesday, July 6th 2011, 5:01pm
We do not sell ACFluid anymore. Its successor is DP Ultra (a ready to use coolant). You can also use it without as long as you do not have mixed metals in your loop but anyway it is not recommend.
I'm not quite sure what you mean with "mounted parallel to the water surface"?! The sensor surface can only detect an accurate fill level when it is mounted vertically into the water.
CyberMarine
Wednesday, July 6th 2011, 6:32pm
When the aquatube is mounted horizontally with a flush jet also mounted horizontally in the center, the tubemeter can't be mounted vertically (perpendicular to the water surface) without bending it a little. Bending it just makes me cringe. :S
If I remember correctly though, the YouTube demo for the aquaero also shows a tubemeter mounted in a slanted position with a aquajet. It appeared to be bent as well.
Maybe I should just forgo the aquajet?
Phos
Friday, July 8th 2011, 8:55am
If you have the aquatube in the 5.25 bays, can't you just look at the water level?
And are you talking about the video for the Aquaero 4? That aquatube doesn't appear to have a flush tube.
