• 29.11.2026, 15:02
dopax007
Doubts about the compatibility of the Aquagrafx for GTX570
Friday, July 8th 2011, 10:36pm
Greetings :
I would like to know if any of the two products Aquagrafx for GTX570 is compatible with my GPU MSI GEFORCE GTX 570 TWIN FROZR II/OC 1280Mb DDR5 750Mhz .
Thank you in advance
Monday, July 11th 2011, 11:55am
The Frozr II/OC should use the regular reference layout so you can use the GTX580/570 block in copper or nickel plated.
dopax007
Monday, July 11th 2011, 5:16pm
Greetings , Shoggy ;
According to the cooling configurator of EK, also gave it as a PCB of reference but i wanted to confirm, and you've already done . Thank You
This post has been edited 1 times, last edit by "dopax007" (Jul 13th 2011, 6:26pm)
Similar threads
