• 11.10.2026, 15:23
FutureCorp
Lost control of the aquaero via the aquasoft 2012(Problem found, Conflicting with Logitech Setpoint)
Wednesday, July 13th 2011, 12:50pm
Hi.
I can't use any function in the aquasuite 2012 software anymore.
I did a factory setting reboot, a reinstall of the aquasuite, but nothing changed.
Something of influance could be that i installed, the lcdhype and the plugin for it. (already de-installed it and no changes)
When i enter the aquasuite the first thing that's different than before, is that all the temp-sensors are "blank". I mean they have no name, not even "temp sensor 1". I can however name them, but it changes nothing on the A5. When i click a virtual sensor i get a a4-long error message and the Asuite exit's
Anyone any Idea how i got into this mess? Or how to solve it?
Ps, firmware update via the aquasuite, cause the aquasuite to crash. The device states its firmware 1012.
Another thing that's funny is that the aquasuite apperenlty does read information from the A5 but it seems it cannot return any.
UPDATE:
I'was thinking about what i changed since the last time everything(well everything grmblf) still worked. I took out my logitech mouse - not the keyboard btw - and turned off the Setpoint application. Windows than installed my keyboard as a standard keyborad. Launched the Aquasuite and now i was able to fully controll the aquaero 5 pro again.
Is this a know issue?
Would it help using a different usb port? (can't see why, but i will give it a go)
Edit2:
Tested: logitech keyboard and mouse on a different usb hub/port(backpanel instead of front) and now everything seems to be working fine.
This post has been edited 3 times, last edit by "FutureCorp" (Jul 13th 2011, 1:58pm)
FutureCorp
Wednesday, July 20th 2011, 2:04pm
Hmm, The problem returned, only different.
I Recently developped problems with the keyboard or mouse. I stuck them by test into the front usb and the keyboard and mouse went completly out of wack. Mouse was shocking and keyboard was putting out key's i did not pressed.
So i returned the keyboard and mouse to the backpanel usb's And they are working normal now. But now i have the same problem as before iwth the Aquaero 5. I can't communicate with the device using the aquasuite.
I tried unplugging the aquaero and even a restart. Both to no succes. Keyboard works but the aquaero not. Or its the other way around.
Anybody any idea how to solve this problem. I already have all updates(mouse+keyboard and usb-mobo) I use Windows 7 x64.
Anyidea if this is caused by the Aquaero, the usb mouse/keyboard, windows 7 or maybe the Motherboard(usb-hub)
Should i report this problem to AquaComputer, or is it just enough to post it here?
This post has been edited 1 times, last edit by "FutureCorp" (Jul 20th 2011, 4:08pm)
Jays_sho
Tuesday, August 9th 2011, 11:54am
Had the same problem...Im useing win7 ult 64bit and I turned off UAC in user profile setting and then ran aqua 2012 as admin...now everthing works. I hope this helps you.
Jays_sho
