• 10.10.2026, 11:14
Addicted
Will the Aquero 5 XT be able to run my setup ok?
Wednesday, July 13th 2011, 9:56pm
I just wondered if the XT would be able to control the following without me having to buy any extra items?
6x Xilence XPF120R 120mm (Radiator) apparnetly they're 0.07 A and 0.84W
3x 140mm Corsair fans from Corsair 800D case.
1x XSPC Dual 750 Bay & Res Pump (750 lph)
Thanks,
Matt
Phatboy69
Thursday, July 14th 2011, 7:58am
Looks ok to me but any time you put a pump on you need some active air cooling on the heatsink or the waterblock.
I am Intel of Borg. Resistance is futile. You will be assimilated.
i7 3930K @5Ghz - X79 ASUS Rampage IV Extreme - 4x SLI GTX580 - 16GB DDR3-2000 - 4x GTX 360 rads 24x CM fans - Aquaero 5 XT +6 PA2 Ultras - 2 x Enermax 1500W PSU - MM Extended Ascension Case - 2 x 452x2 Res and 4 x D5 - 3 x 24" Acer H243H LCD
Addicted
Thursday, July 14th 2011, 10:53am
ok thanks, i'll leave the pump out of the loop for now then :)
