• 20.11.2026, 14:13
Kentigern
How to setup software sensors for Aquaero 5/Aquasuite
Monday, August 8th 2011, 12:27pm
All I seems to be able to do is set a fixed temperature. I want to be able control my pumps and fans based on CPU/GPU temperature.
Is this a sensible thing to attempt? Or should I be looking to use physical sensors? I currently have a sensor attached to the CPU block but I am worried because while stress testing there seemed to be very little relationship between the temperature this probe reports and the CPU temperature reported by ASUS PC Probe II and HWMonitor.
acutech
Wednesday, August 10th 2011, 4:12am
Hi Kentigern,
software sensors will be supported only in later versions of the aquasuite 2012, using a tool called "Open Hardware Monitor". Just be patient, it will come eventually...
Regards,
Similar threads
