• 23.11.2026, 01:40
tylerplowright
Linking Aquaero 5 XT and LT in Aquasuite 2012
Sunday, August 21st 2011, 9:15am
Hey,
Bought these a while ago and was unsure if the software was able to do this as yet? Bought the 3 pin fan cable to connect the aquabus (which I was told was how it was going to be setup so that the LT is a slave) and currently its plugged into the "high" side plug on both. Both are also connected to the computer via a usb cable. When I open aquasuite I can connect and see all the information for the XT however when I try and see the settings and things for the LT it just doesn't work and crashes. It also comes up with the following error and as soon as you click ok, it then closes/crashes the program. http://imageshack.us/photo/my-images/705/unledujz.jpg/
Any help would be great, and both cards have the latest 1013 firmware (i think thats the version that is the latest)
Thanks
Tyler
EDIT: also do you have some stats on flow rate or anything like that for the aquastream xt? Currently using 2 x mcp-655's in series (getting 170ish litres per hour) and looking at replacing them with the 1 aquastream xt in the hope of higher flow rates.
This post has been edited 1 times, last edit by "tylerplowright" (Aug 21st 2011, 10:21am)
Sunday, August 21st 2011, 7:15pm
You can not connect an aquaero 5 to another aquaero 5 so please remove this connection. Maybe it is also the reason for the other problems.
If the LT still does not work correct you can try to perform a reset of the device: Remove all unnecessary connections with exception of the power. When turned off, place a jumper on the temperature sensor 8. Start the device afterwards, wait for a few seconds, turn it off, remove the jumpers, attach USB and run the aquasuite. Normally it should work now.
The flow rate of the aquasuite depends a lot on the resistance of the loop and the frequency which it runs. In a "normal" setup you would reach a flow rate somewhere around 130 l/h.
tylerplowright
Monday, August 22nd 2011, 3:15am
Thanks shoggy, worked a treat. Now i have access to both. Haven't really explored this yet, but could i potentially setup the XT so that any sensors that are on the LT come up on the lcd display as well?
Thanks for the pump flow. Do you have any more info such as flow vs pressure drop charts, or even a "normal" loop flow rate for the following pumps? Looking for comparisons to see if its worth it.
aquastream XT USB 12V Pump (all three versions, if it makes a difference at all which from what i read it does not)
Eheim 1250 (Version Germany) - also whats the difference with version germany?
Aqua Computer D5-Pumpenmechanik mit Tachosignal
Also, how many aquastream XT's can you connect to an aquaero XT and LT each? Possibly looking at putting two in each loop with 1 flow meter for each loop. Could you also mix a standard and an ultra? Seeing as you'd only really need 1 internal temp sensor, and the 1 flow meter? And what kind of performance gain would having two in series get you? Alternatively would two in parallel get you greater performance gains?
Thanks
Tyler
This post has been edited 1 times, last edit by "tylerplowright" (Aug 22nd 2011, 3:46am)
Monday, August 22nd 2011, 9:55am
Exchanging the sensor values is not possible yet. Maybe it will work with the software sensor function or in the far future as a slave device directly through aquabus.
There are many reviews available for that pump including charts: click
You can connect two pumps via aquabus to an aquaero. Of course it does not matter which variant you use. So running a standard and ultra is no problem. I have not much experience with two pumps in series but would say it brings less performance than most users would expect.
tylerplowright
Monday, August 22nd 2011, 11:42am
Thanks again for that info. Good to finally find a flow chart for it.
I've heard that the pumps automatically sense the load and adjust the pump, and when put in series this causes problems as neither senses the full load and as such doesn't spin as fast as i probably needs to. Is there a way to manually (or automatically via some configuration much like you do with the fans) set the frequency/flow rate of the pumps if you had them in series?
Thanks
Tyler
Monday, August 22nd 2011, 12:55pm
Normally you will get a higher frequency with a higher resistance in the loop.
You can adjust a manual frequency but the rotation control is still the same and works in the background. So when for example a frequency of 80Hz is the maximum in the automatic mode, it will also be 80Hz in manual mode since you are not able to push the frequency beyond this limit because with a higher frequency the rotor would not run stable.
tylerplowright
Monday, August 22nd 2011, 1:56pm
Excellent, thanks for that again.
Last questions, if you put them in series with each other, in theory the pressure would drop as they're both helping to push water and as a result the frequency would be lower, but would they run at the same frequency?
Also if you put them in parallel would you in theory get a situation where you wouldn't get a greater water head, least not by much, but much greater flow as both would be working to push the pressure hence working at the same/higher frequency?
Do you need to plug every pump into a usb port? or will plugging them into power, and to the aquaero suffice/be enough to control them fully? Can you plug the aquastream into the aquabus on the aquaero as well as have a flow meter plugged into the pump? Or do they share the same header on the pump and the only way to get it to work would be to plug the flow meter into the aquaero in the flow meter plug? Found out its one or the other
Do you also have some diagrams/measurements of the aquastream XT? Looking at linking them and need to know distances of the inlets/outlets so I can get the right fittings.
Thanks again for all your help shoggy
Tyler
This post has been edited 2 times, last edit by "tylerplowright" (Aug 22nd 2011, 2:16pm)
Monday, August 22nd 2011, 3:08pm
It is very unlikely that they will run at the same frequency since already production tolerances will cause differences.
I have no experience with the mentioned setups so I can't tell how it would affect the flow rate.
Of course both pumps must be connected to the PSU and I highly recommend to connect both pumps via USB since the aquabus only provides some basic functions which are pretty useless compared to the USB connection.
Dimensions:
Ohne grauen Filterdeckel = without gray filter-cap.
Mit Bodenplate = with base
