• 09.10.2026, 19:24
Okkur
aquastream xt usb connection..
Tuesday, September 20th 2011, 11:33pm
Hello,
I just bought an aquastream xt ultra pump, and it's working ok without any usb connection. The thing is, I wanted to try my hand at the aquasuite software, and decided to connect the pump to the usb on my motherboard.
I followed the directions in the manual (although it doesn't say how you are to connect it to the mobo, on the upper pins or lower pins? I did the upper..).
I booted, installed the aquasuite 4.72, and... Nothing happened.
Anyone know what I did wrong here? Is it supposed to show up in device manager? If so, under what name?
Thanks ;)
Silvermaul
Wednesday, September 21st 2011, 7:40pm
Did you try the find usb device option in the suite?
It will not appear in the device manager. At least it doesn't appear in my case but the old aquasuite software works fine.
Okkur
Wednesday, September 21st 2011, 11:38pm
Yes I did, and nothing much happens.. Very annoying ?(
Namron
Thursday, September 22nd 2011, 12:03am
First be sure you have the usb plug in the correct orientation for the Motherboard pin layout......... failing that.....
If you already had the USB connected when you installed the Aquasuite 2012 software, that can cause this problem. It might be worth trying disconnect the usb & then re-connect it, if that doesn't work then try installing the software again BUT this time make sure the USB is NOT connected, Once you re-install the aquasuite software then plug the USB in making sure the usb plug orientation is the correct way around for the M/B header.....
Good luck :)
N.
This post has been edited 1 times, last edit by "Namron" (Sep 22nd 2011, 12:09am)
Okkur
Thursday, September 22nd 2011, 12:51am
Thanks for the tip, I'll look into that!
Thursday, September 29th 2011, 9:20am
Only a short info: the aquasuite 2012 is not compatible to the aquastream XT yet so it will only work with the aquasuite 4.xx at the moment.
Similar threads
