• 10.10.2026, 02:44
soth
Poweradjust 2 Ultra USB's automatically speeding up to 100% pump speed by themselves, help!
Monday, September 26th 2011, 2:09pm
I have 6 x Poweradjust 2 Ultra USB's standalone (one to power each pump), they are not connected to an aquaero or via aquabus yet.
Each poweradjust is connected to a single Laing DDC using the supplied adapter cable (including the rpm signal), no other tempreture sensors,fans, or flow meters are connected.
Each poweradjust 2 Ultra is using the latest firmware (1003).
Despite setting each of the Poweradjust's individually via USB in the aquasuite software and , to NEVER use more than 80% power, or speed the pumps past 2000rpm, after approximately 5 minutes of operation each of the poweradjust speeds up to 100% power and 100% rpm!
Screenshots of settings are below:
Can anyone please tell me what I am doing wrong here? I just want to run my pumps at a lower speed as my flow rate is way to high! ( and in future monitor them with an aquaero xt pro )
Please help!!! this is driving me insane!!!
(ps external operating temperatures are fine - 15 degree's celcius ambient)
This post has been edited 1 times, last edit by "soth" (Sep 26th 2011, 2:10pm)
Monday, September 26th 2011, 2:53pm
you have set up the pump to run with rpm set point of 2000rpm.
soth
Monday, September 26th 2011, 3:02pm
Yes that is what i intended to do,
What my problem is, is after 5 minutes, all the pumps speed up to 4400rpm, and 100% power by themselves! (instead of staying on 2000rpm).
Tuesday, September 27th 2011, 8:33am
make screenshots when the poweradjust dosen´t run how do you expected it.
