• 08.10.2026, 14:13
presidio
AC high flow sensor
Monday, October 3rd 2011, 9:48pm
Hello,
I have two questions about AC high flow sensor:
1.) What is the calibration value for that AC high flow sensor. I'm looking value's in l / h. In
AquaSuite I see default calibration value 256. Is this OK? First there was a talk about calibration factor 169.
2.) The third sensor is making some noise like click click click .... and i think something is
wrong with it. I have triple loop and the third sensor constantly changes values. All sensors are
in horizontal position.
First sensor is showing value of 147 l / h, second one 180 l / h and the third from 105 to 120 l / h.
What I need to do?
Thanks,
Simon
b0nez
Monday, October 10th 2011, 4:56pm
The Factor is 169. In the Aquasuite or at the device (AE4 + AE5) you can choose if you want the flow in l/h or l/min.
If you open the flow sensors you can see the axle on which the wheel is turning. Sometimes the axle is a little bit lose and you will hear the noise. You can try to fix it with a some gentle hits on the axle.
Hope a could help you.
Greetings
b0nez
:rolleyes:
Presidio
Tuesday, October 11th 2011, 2:19pm
Thank you for you replay.
I set the default value to 169. I asked for that because in new version of Aqua Suite default value was set to 256.
I tried to set the axle to a stable position with gentle hits, but the noise didn't stop.
This post has been edited 1 times, last edit by "Presidio" (Oct 11th 2011, 2:21pm)
