• 29.11.2026, 14:47
alstorm
[Solved] Front Panel Screw size/type?
Saturday, November 12th 2011, 9:27am
Forgive me if I have missed this information, I have tried searching both the forum and google...
I am looking to replace the Aquaero 5 front panel screws with black coloured parts
What size and type are the front panel screws for Aquaero 5 (and also PA2 Ultra front plate)?
This post has been edited 1 times, last edit by "alstorm" (Nov 15th 2011, 6:13pm)
Qrt
Saturday, November 12th 2011, 12:37pm
looks like a torx size 8 bit works best
you can also use hex (inbus) size 2 metric or size 5/64 imperial
alstorm
Saturday, November 12th 2011, 4:32pm
Maybe I wasn't very clear...
I need to know the size and type of screw >itself< - e.g. is it M3, M4 UNC 6/32, how long is it?
I have a kit with plenty of screwdriver heads etc so I am confident there I can find something that works to remove and re-fit the screw, I really just need to know the screw type and dimensions so I can buy some black replacements.
Nihil Simile
RE: Front Panel Screw size/type?
Tuesday, November 15th 2011, 1:04am
The screws are M3 metric and about 5MM long.
Tuesday, November 15th 2011, 3:34pm
aquaero 5 PRO = M3 x 5
aquaero 5 XT = M3 x 8 countersunk head
