• 18.11.2026, 22:55
shteud
Few questions about Aquero 5
Sunday, December 4th 2011, 2:14pm
I want to buy Aquero 5 and have question:
1. Will simple heatseank( quet fan on it) be anough to control 2x dcc (12w) 1-2 fans with AE5 ? I realy don't want install waterblock on AE5.
2. If i buy now AE5 LT, can i buy later LCD and ir module and install ? I see interface on back board of LT.
3. I have Logitech G - series mouse and keyboard (G700 & G15v 2). Will AE5 work properly ? Can i flash firmware AE5 ? Or i need to disconnect Logitech device to flash AE5 ?
4. will Aqua-Computer PowerAmp for Aquaero work with AE5 ?
Be greatful for any advice!
This post has been edited 1 times, last edit by "shteud" (Dec 4th 2011, 3:58pm)
Phatboy69
Monday, December 5th 2011, 8:03am
I can answer those for you...
1. That should be fine but im not familiar with the DDC pumps power draw. If it's really only 12w each thats only 1Amp so should be fine.
2. No there are no upgrade kits for the LT at this time.
3. I have Logitech G19 and peformance MX working fine with AE5XT. The Aquasuite 2012 beta 9 throws a few startup errors with my Track-ir 4 enabled though. That's a new problem that didnt exist previously for me, so hopefully the next firmware/beta will correct it.
4. No the poweramp is not compatible with AE5.If you need more than 1.65A per channel buy the slave Powersdjust 2 units which connect to the AE5 as additional channels. You can have up to 6 PA2's for a total of 10channels on the AE5. They link in series.
I am Intel of Borg. Resistance is futile. You will be assimilated.
i7 3930K @5Ghz - X79 ASUS Rampage IV Extreme - 4x SLI GTX580 - 16GB DDR3-2000 - 4x GTX 360 rads 24x CM fans - Aquaero 5 XT +6 PA2 Ultras - 2 x Enermax 1500W PSU - MM Extended Ascension Case - 2 x 452x2 Res and 4 x D5 - 3 x 24" Acer H243H LCD
shteud
Monday, December 5th 2011, 10:49am
Thanks!
Yes it's modified DDC (diyhink) and they must consume 12W(1A) MAX. Maybe then they start, consume more. How do you think, small 40mm fan on AE5 heatsink would be enough ?
It's pretty sorry about lcd. AE5 pro/xt is expensive and modular :) It would be very nice to have the opportunity to increase the functionality of AE5 gradually.
I've seen reports that the flash firmware AE5 with peripherals Logitech G-series are sometimes not possible. Is there any way around this?
Phatboy69
Tuesday, December 6th 2011, 4:35am
I use a Corsair Ram fan to cool my PA2s so I guess anything simliar will do the job at a minimum of about 2500-3000rpm for smaller fans.
You could use a standard keyboard /mouse during flashing or do it externally with another PC.
This post has been edited 1 times, last edit by "Phatboy69" (Dec 6th 2011, 4:37am)
shteud
Tuesday, December 6th 2011, 10:19am
O i see on some builds these coolers on AE5. Ok, its good idea. I find ram cooler.
Thanks for helping.
I hope no problems (and questions) will come with using ae5 :)
Similar threads
