• 04.10.2026, 02:14
aster1x
Aquastream XT Ultra pump and regulator data
Wednesday, December 7th 2011, 10:44pm
In the Aquastream XT Ultra under the tab fan of the Aquasuite 4.72 what is the meaning of the parameters R regulator, I regulator, D regulator? These parameters are also graphed under the regulator data in the diagrams tab of the Aquasuite. How are these used?
Regards
Aster1x
Tuesday, December 13th 2011, 12:30pm
Have a look here. Should help a bit to understand it ;)
aster1x
Wednesday, December 14th 2011, 9:15am
Thank you shoggy for the reply. Unfortunately your comments are not sufficient to understand how to use these parameters. Experimentation takes a long time. It would be usefull to give us more technical information on how these parameters are defined and what they affect. Also what are the relations between them?
I hope you can give us a more technical answer.
Regards,
Aster1x
Wednesday, December 14th 2011, 11:28am
Unfortunately that can not be explained in a few words. For a very detailed description you can check the entry at Wikipedia. I have already tired to explain it in a few simpler words.
Otherwise just go with the assistent function and the presets. They normally do not require any special adjustments and work good for the most users.
aster1x
Saturday, December 17th 2011, 11:48am
Thank you very much shoggy. This is the kind of material I was looking for. I agree with you it is not easy to explain it in simple terms.
Regards,
Aster1x
This post has been edited 1 times, last edit by "aster1x" (Dec 29th 2011, 3:56pm)
