• 29.05.2026, 21:23
knacker
Aquaero Pro 5- help with setup
Tuesday, December 13th 2011, 1:33pm
Noob here needing help to setup. Have 3 fans and waterpump and would like to see flow. pump is laing with 3pin header- do I just install on fan 1?
edit: have got flow reading working by plugging 3 pin into flow input- duh but is there a way to control the speed of the pump- it seems to be on at 100% and very very noisy?
This post has been edited 1 times, last edit by "knacker" (Dec 13th 2011, 2:15pm)
Nihil Simile
DDC Pump
Tuesday, December 13th 2011, 11:08pm
You need to have the pump hooked too a fan header,this is how you can control flow just like a fan and in the same way as a fan. The flow header is for a flow sensor
I use a Power Adjust 2 to run my DDC, it showed up as Fan 5, you can go to menu of your Aquareo and change the name to PUMP this works on all fan headers.
Nihil Simile
DDc Pump
Tuesday, December 13th 2011, 11:15pm
I just wanted to add that it seems the DDC Pump has a 100% start up voltage for about 3 seconds. this thew me off at first I thought I didn't have it set up correctly. My Pump is a
Laing DDC Ultra 600 Lh. Just wanted to correct this it seems that the PA2 has the 100% voltage when it has no RPM signal, this why when I first turn it on it runs at full speed until it sees a RPM signal.
This post has been edited 1 times, last edit by "Nihil Simile" (Dec 15th 2011, 6:42pm)
knacker
Wednesday, December 14th 2011, 11:07am
so would it work if I used a 3pin splitter and plugged on end into the flow meter and one end into a fan header?
Wednesday, December 14th 2011, 11:46am
I am not quite sure what you want to do there but it sounds very wrong to me. You should get an adapter so you can connect the pump directly to one of the fan headers.
knacker
Wednesday, December 14th 2011, 12:22pm
Can you recommend a suitable adaptor please?
knacker
Wednesday, December 14th 2011, 3:45pm
just seen the link- ta
knacker
Tuesday, January 10th 2012, 11:18am
Can anyone tell me how to install this cable. I presume the molex goes to a molex from psu but the single male out goes where and female where
TVMIA
This post has been edited 1 times, last edit by "knacker" (Jan 11th 2012, 12:18pm)
Nihil Simile
Thursday, January 12th 2012, 2:12am
The molex plugs into the molex from the DDC pump, the single pin wire plugs into the Tach wire from the DDC pump, then the three pin Fan type connector plugs into an available fan header on the Aquaero, or you can get a crimp tool and set the pump up like this.
knacker
Dual loop help needed now!
Friday, April 13th 2012, 3:05pm
I am now running a dual water loop and have got 2 poweradjust cables for the pumps- is there any fan header to use for them or any of the fan headers would do? I would like to be able to regulate the flow of the pumps- I have all of the 6 fans on a fan controllor so I can adjust them manually but wondered if it can adjust the pump flow like a fan?
TVMIA
Thursday, May 10th 2012, 2:39pm
You will need a fan controller that provides a lot of power. The pumps draws up to 30W for a short period of time when it spins up.
