• 29.11.2026, 04:23
Psychor
Aquasuite 2012 & software senors?
Thursday, December 22nd 2011, 10:04pm
How exactly does this work? What software can AS 2012 pull information from? Is AIDA64 (http://www.aida64.com) supported?
Thank you.
Friday, December 23rd 2011, 11:44am
You will need the software sensor tool and for example a modified Open Hardware Monitor version. AIDA64 (registered version only) and Speedfan can be used too.
Configure and activate the software sensors in aquasuite 2012. Start OHM, AIDA64 or Speedfan and run the software sensor tool and select which temperature you want to forward to the aquaero.
