• 14.11.2026, 15:25
TheDude0901
Curve controler doesn't work?
Saturday, January 7th 2012, 3:09am
Greetings,
I am trying to get the curve controler to work but am not having any luck at all.
I have an Aquacomputer 5 LT
Firmware 1019
Aquasuite 2012 Beta 10
I've set up a linear curve starting at 80F to 125F and the powe goes from 50% to 100%.
My data source is Temperature Probe 1
No mater what temperature that probe is reading the fans will not turn on.
After some searching I found this post where Shoggy mentioned the curve controler had not been integrated into Aquasuite yet. However, that was for version 2012 Beta 6 and firmware 1013. Please tell me this has been fixed since then otherwise this thing is utterly useless to me and will have be returned. ;(
Aquaero 5 LT Fail--Firmware 1014 / Beta 6 bricked it!
mm67
Saturday, January 7th 2012, 9:35am
Curve controllers are working fine with my LT.
bcikota
Sunday, January 8th 2012, 2:45pm
Hi TheDude0901,
A stupid question, did you actually assign fans to the Curve controller?
If you are setting it up using Aquasuite, on the left you have the Data source window, in the middle is the actual Curve controller window and on the right you have to assign fans to the controller.
Kind regards,
Boris.
