• 22.11.2026, 22:05
Rioga
Aquero 5 12V PWM outputs
Sunday, January 15th 2012, 1:20pm
Hi all!
I receive my aquaero 5 LT a few weeks ago and still playing with it. I love it!!!
I'm planning to connect this type of led light to one of the 12V PWM output of the aquaero. Is it possible? Somebody tried?
I Know this PWM outputs can handle 1A, but I don't know if the led's consumption could be high than that.
Questions:
1.Can I connect this kind of led's to the 12V PWM outputs of the aquaero?
2.Can I control the bridges of this kind of led's with the PWM signal?
Thanks!!
This post has been edited 1 times, last edit by "Rioga" (Jan 15th 2012, 1:21pm)
spritzring
RE: Aquero 5 12V PWM outputs
Sunday, January 15th 2012, 5:10pm
1.Yes
2.Yes
TheSmoker
Sunday, January 15th 2012, 8:38pm
Cn someone tell me how it can be done? In AS2011 only the relay output is visible to me. I have an 5 XT. Thanks!
Rioga
Sunday, January 15th 2012, 9:19pm
Thanks
spritzring for the quik answer!!
Can someone tell me how it can be done? In AS2011 only the relay output is visible to me. I have an 5 XT. Thanks!
[img]http://desmond.imageshack.us/Himg16/scaled.php?server=16&filename=img9584e.jpg&res=medium[/img]
In AS2012, go to Aquero5, controller, create a new controller type (for example constant value) and assign one power output into the outputs:
Regards
This post has been edited 2 times, last edit by "Rioga" (Feb 29th 2012, 8:49pm)
etoel
Saturday, February 25th 2012, 12:24am
Thanks
Regards
Were you happy with the result? Do you just turn them on and off or anything more fancy? :)
I see you used a preset value in your answer, but your original question asked if yoy could control the bridge (?) - is that a controlling device that could change color/intensity?
Rioga
Wednesday, February 29th 2012, 8:44pm
I use this preset value to make the leds more or less bright. I'm very happy with the result, here u can see it:
[img]http://desmond.imageshack.us/Himg46/scaled.php?server=46&filename=img9581t.jpg&res=medium[/img]
You can associate a temp to the leds bright too.
It works pretty fine.
Regards!
This post has been edited 6 times, last edit by "Rioga" (Feb 29th 2012, 9:02pm)
