• 22.11.2026, 23:10
edman911
Aquaero 5 XT Fan 1 dead?
Wednesday, January 18th 2012, 4:30am
I had my D5 Basic pump connected to Fan 1(power and rpm) on my Aquaero 5 XT. I turned the voltage down to 70% to test the flow rate of the loop, then all of a sudden I'm getting zero voltage out of that header. Power is at 100% and low(.08 V) to no voltage. The pump will not turn on when connected to the Aquaero. I plugged the pump into a dedicated power connector right off the PSU and it works fine. In fact the Aquaero still reads the RPMs intermittently when the pump begins to move while connected to the PSU. All of the other fan headers work fine. I've reflashed firmware to1020, restarted, ect... All Fan Amp temps are between 38- 50c depending on voltage. Any help would be greatly appreciated.
edman911
Wednesday, January 18th 2012, 9:36pm
Anyone?
Nihil Simile
Wednesday, January 18th 2012, 11:55pm
Sounds to me like its dead.
Psychor
Thursday, January 26th 2012, 2:49am
Post removed.
This post has been edited 1 times, last edit by "Psychor" (Jan 27th 2012, 5:40pm)
Similar threads
