• 22.11.2026, 21:34
Some_Nob
Flow Sensor Calibration Value
Saturday, February 25th 2012, 6:50pm
Hello, can anyone tell me Calibration represents...
I have a Koolance FM17 and a RPM adaptor, basically the adaptor is putting out a RPM signal equal to mL/min.
So if its signal is 2000rpm it means 2L/min how to calibrate that into the Aquaero 5 so it represents correctly.
Ive put in 1000 guessing thats what it would mean.. but like a confirmation.
Cheers.
SteinerKD
Sunday, February 26th 2012, 12:18pm
In this thread someone is using FM17 with Aquaero and suggest calibration set to 169, he doesn't say what tubing he uses though (I've seen that number for the plug n cool stuff). The calibration is dependent on the tubing though and in a review (of ACs "high flow" sensor) I read 158 was suggested (I think that was for 10-11 ID tubing).
Nihil Simile
Sunday, February 26th 2012, 6:44pm
I was told by support when using the Aquacomputer High Flow like the one that is being tested, you should choose the High Flow option in the Aquareo calibration menu.
