• 19.10.2026, 22:15
IceByte
Aquaero 5 Pro not found by aquasuite
Monday, February 27th 2012, 11:14pm
I've recently gotten a Aquaero 5 Pro, and i connected it to a USB port, but the Suite doesn't find it when scanning for devices. Any suggestions to why it cannot be found? As far as i can tell the USB connection is connected properly.
This post has been edited 1 times, last edit by "IceByte" (Feb 27th 2012, 11:22pm)
XNine
Saturday, March 3rd 2012, 9:15pm
This is typically because your USB header is plugged in upside down. Try flipping it and AS should find your aquero. You may even be able to do this while the computer is on (though don't blame me if you short something).
IceByte
Tuesday, March 6th 2012, 12:23pm
I connected it using the same color coding as my native USB headers, but no result, so i tried flipping it, that made my PC find an unknown device, but it won't install it. The OS used is Win7 X64
XNine
Thursday, March 8th 2012, 6:11am
Interesting. I'm using Windows 7 x64 as well.
Unplug the cable, start Aquasuite, then plug the cable back in. Aquasuite should pick up the controller automagically.
IceByte
Sunday, August 26th 2012, 4:47pm
This problem still exists, i did a full reinstall, the AQ5 is running, and i can see the onscreen info, the new B16 suite starts, but no options to choose from, still an unknown device in the device manager :cursing:
chippie
Sunday, August 26th 2012, 6:34pm
If you unplug the Pro from the MB header does it still show an unknow device. Just checking in case it is not picking up the Pro at all.
Once you determine this, and it is showing the Pro as an unknown device. Unplug your mouse (if a USB mouse and reboot the system, then try to update the driver for the unknown device (I know it may be a little tricky without a mouse and you do nto have a spare one) run AquaSuite and see if that helps. Some users have reported that their USB mice interfere with the connection to the Aquaero but this is normally for firmware updates, worth a try though.
It is clearly an issue that Windows is not picking up the Pro properly or not able to install the driver correctly. If the above fail do you have a spare USB header cable you can try, also double check that it is wired correctly. I am assuming you have full admin rights to Windows, just in case.
This post has been edited 1 times, last edit by "chippie" (Aug 26th 2012, 6:36pm)
chippie
Sunday, August 26th 2012, 6:47pm
Sorry, just re-read your post, ignore the first part of my post.
IceByte
Monday, August 27th 2012, 2:39pm
I have no clue if i can manually install the needed usb driver, if that's possible, i might be able to get the thing to work
cc01
Tuesday, August 28th 2012, 4:46am
Have you tried updating the driver in "Device Manager" under "Control Panel"?
When you open device manager, you should see an icon with a question mark attached to it for any unknown device on your system. If you right-click on the icon a menu will pop up with the option to "Update Driver Software" or alternatively you can go into "Properties" and then under the "Driver" Tab is a button to "Update Driver".
This post has been edited 1 times, last edit by "cc01" (Aug 28th 2012, 8:26am)
Thursday, September 6th 2012, 12:49pm
There is no special driver required at all.
All our USB devices are programmed as HI-Devices like you may know it from keyboards or mice. Every operating system can detect these devices and the software just communicates with the device directly.
Make sure that you are using the aquaero 2012 because "scanning for devices" sound a bit like you are using aquasuite 4.72 which is not compatible to the aquaero 5.
If it does not work on your PC, have you tried it on another to check if maybe your PC is the problem?
