• 30.09.2026, 16:25
M3rl1N
HILFE mein Browser lebt... Virus ?
Sunday, March 4th 2012, 12:52pm
http://p4.cizabsoy3pwli.glbdghqvzbsdvftb…exp/iframe.html
http://p4.eiwtr3ifgrq5y.5rjuhqj5zbdsubph…exp/iframe.html
so links wie den da oben (lik adresse ändert sich zwischen dem p4. und if.v4. ) öffnet der browser öfter mal ( alle 20-30min nicht absolut regelmässig und meist nur im leerlauf) von alleine und es bleibt dann eine blankpage (optisch)
mit folgendem quelltext:
Source code
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
<!DOCTYPE html>
<html>
<head>
<title></title>
</head>
<body>
<script type=text/javascript>
(function() {
var f=this,g=function(b,d){var a=b.split("."),c=f;!(a[0]in c)&&c.execScript&&c.execScript("var "+a[0]);for(var e;a.length&&(e=a.shift());)!a.length&&d!==void 0?c[e]=d:c=c[e]?c[e]:c[e]={}};var i=function(b,d){function a(b){e!=null&&(c=Math.abs(new Date-e),b&&(c*=-1))}var c=-1,e=null;this.h=function(){var c=new Image(0,0);c.onload=function(){a()};c.onerror=c.onabort=function(){a(!0)};e=new Date;c.src=b};this.k=function(){return d};this.l=function(){return c};this.d=function(){return[d,c].join("=")}},j=function(b,d,a){this.a=String(b);if(this.a.charAt(0)!="p")this.a="p"+this.a;this.j=d;this.i=a;this.e=Math.floor(Math.random()*9E5);this.e+=1E5;this.c=function(){return[this.a,this.j,this.i,
this.e].join(".")}},k=function(b){for(var d=["i1","i2"],a={g:"v4_img_dt",f:"v4.ipv6-exp.l.google.com"},c={g:"ds_img_dt",f:"ds.ipv6-exp.l.google.com"},e=[],e=Math.random()>=0.5?[c,a]:[a,c],h=[],a=0;a<d.length;a++)c=new i(["http://",[b.c(),d[a],e[a].f].join("."),"/intl/en_ALL/ipv6/images/6.gif"].join(""),e[a].g),c.h(),h.push(c);setTimeout(function(){for(var a=["/gen_204?ipv6exp=3","sentinel=1"],c=0;c<h.length;c++)a.push(h[c].d());a=["http://",[b.c(),"s1.v4.ipv6-exp.l.google.com"].join("."),a.join("&")].join("");
(new Image(0,0)).src=a},3E4)},l=function(b,d,a){var c=new j(b,d,a);setTimeout(function(){k(c)},1E4)};var m=["v4","ds","w","l","q"],n=function(){this.b={};for(var b=0;b<m.length;b++)this.b[m[b]]=0;for(var d=[],a=(document.cookie||"").split(";"),b=0;b<a.length;b++)if(a[b]=a[b].replace(" ",""),a[b].substr(0,4)=="W6D="){d=a[b].substring(4).split(":");break}for(b=0;b<d.length;b++)if(a=d[b].split("="),a.length==2){var c=parseInt(a[1],10);if(!(isNaN(c)||a[1].charAt(0)=="+"))switch(a[0]){case "v4":case "ds":case "w":this.b[a[0]]=c>0?c:0;break;case "l":case "q":this.b[a[0]]=c}}};
n.prototype.d=function(){for(var b=[],d=0;d<m.length;d++)b.push([m[d],this.b[m[d]]].join("="));return b.join(":")};g("w6dCookie",n);g("ipv6iframe.runExperiment",function(){var b=window.location.hostname.split(".");b&&b.length>=3&&l(b[0],b[1],b[2])});g("ipv6iframe.preSentinelCallback",void 0);g("ipv6iframe.extraSentinelQueryString",void 0);
ipv6iframe.runExperiment();})();</script>
</body>
</html>
Source code
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
<!DOCTYPE html>
<html>
<head>
<title></title>
</head>
<body>
(function() {
</body>
</html>
was ist das? virus?
im hintergrund laufen noch icq und skype sonst an sich nix
antivir paid norton
This post has been edited 3 times, last edit by "M3rl1N" (Mar 4th 2012, 1:06pm)
SMLunchen
Sunday, March 4th 2012, 2:56pm
N Virus sollte es nicht sien.
Dürte Eiskuh sein.
Äh ich mein natürlich ICQ
Quoted
badyStufe 1
Zum Antworten anmelden
29.10.11
ich habe das selbe Problem mit ähnlichen Bedinungen ( Win7 Prof SP1 x64, Firefox 7.01)..
bei mir tritt das Phänomen erst seit 2-3 Tagen auf, und auch erst seit die neue ICQ-Version (7.6 Build 5620) installiert ist.
Dann öffnet sich das Fenster z.B. http://p4.gtjnibbhoahke.qhsnoqa3wlajhadm…exp/iframe.html
(war gerade vor ca. 10min) und kurze Zeit später stürzt dann der ICQ-Client auch komplett ab bzw. reagiert nicht mehr
- dies war bislang NIE bei keiner Version der Fall.. Das System is übrigens frisch installiert und auch virenfrei laut TrendMicro..
ähnliches Phänomen hier:
https://groups.google.com/a/googleproduc…go/YBOBRfaPqLQJ
nimm doch testweise nen alternativ Client wie z.B. Miranda
M3rl1N
Sunday, March 4th 2012, 9:30pm
hey super danke ok werdi ma trillian oder miranda nutzen ;)
und mal sehen ob es denn weg is
Ani
Sunday, March 4th 2012, 10:43pm
Also wenn man sich mal so anguckt, sieht es sehr komisch aus.
Irgendwie gehts um suchanfragen an google.
Was genau, kann ich dir aber nicht sagen.
Um mehr sagen zu können, müsste man aber mal den Quelltext auseinander nehmen.
Dazu hab ich aber gerade keine lust.
M3rl1N
Monday, March 5th 2012, 12:28pm
hmm mit anderem client oder auch komplett deinstalliertem client ists dasselbe...
Monday, March 5th 2012, 1:42pm
Eigentlich sollte ich die Klappe halten weil ich kaum Ahnung von Programmierung habe, aber hast du vielleicht noch irgendwelche Toolbars installiert, oder mal den Ccleaner drüber gejagt inkl. Cookies löschen usw.?
Ani
Monday, March 5th 2012, 2:01pm
Guck mal was noch so im Autostart ist.
Es kann durchaus sein dass das auch von google selbst kommt.
Irgendwie greift das Javascript nur auf google Server zu, und kommt ja auch anscheind von da.
Deswegen würd ich mal nach google sachen im Autostart suchen.
SMLunchen
Wednesday, March 7th 2012, 11:43am
Schau euch mal den Link an.. Kann sein, dass das irgendwas Google-Analytics oder so ist, aber das scheint laut deren Aussagen mit ICQ zu tun haben. - Jedenfalls wirkt dieser Zusammenhang relativ eindeutig.
Die klassiker kann ich auch empfehlen, CC Cleaner, Hijathis usw. - da sollte man sehen wenn noch irgendwo was hängt. Und ggf. mal unter den Diensten schauen, ob da was ist, was irgendwie da nicht reingehört.
Edit: Eventlog könnte u.U. auch weitere Aufschlüsse liefern.
M3rl1N
Tuesday, March 13th 2012, 11:14pm
also ich hab jetzt alles probiert cleaner adaware etc.... norton kaspersky usw. nix gefunde alle temps gelöscht etc.
es half nur neu aufsetzen... keine ahnung was des war...
Similar threads
