• 20.11.2026, 21:50
chippie
Flow Meter connected to PA2!
Thursday, March 22nd 2012, 4:49pm
Is anyone running a flow meter connected to a PA2?
I am currently using a Koolance INS-FM18 (have a AquaComputer one on order) which when connected to my aquaero 5 XT gives a nice constant reading but as soon as I connect it to one of my PA2's (have tried 3 of them) the reading jumps up and down by around 90%.
Does the PA2 need a firmware update? can it just not handle the flowmeter? as am a little confused why it should be ok on the XT yet all over the place when connected to a PA2.
chippie
Wednesday, March 28th 2012, 6:07pm
Anyone able to try this on their build to see if it works, connecting a flowmeter to a PA2 that is?
TheSmoker
Wednesday, March 28th 2012, 8:09pm
The answer is on this thread: Aquaero 5 Pro + INS-FM17
Cheers!
chippie
Monday, April 2nd 2012, 6:52pm
Thanks but my OP does say that it works fine connected to the 5XT. I only have an issue when it is connected to any of my PA2's.
franknitty69
Tuesday, April 10th 2012, 4:52pm
i have an aquacomputer flow meter and it works plugged into the a5 or a pa2.
Namron
Tuesday, April 10th 2012, 10:55pm
I also have an Aquacomputer flow meter pluged into my PA2 & another Aquacomputer flow meter pluged into my AQ5, All work fine & never had any issues with either
N.
chippie
Sunday, April 15th 2012, 8:48pm
Thanks for the replies, I have a AQ one here now so will give it a try when I can.
Does seem strange though that he Koolance one works ok on the XT but not on the PA2.
Phatboy69
Tuesday, April 17th 2012, 8:49am
The A5 has more processing ability and can filter the signal better. I have the same problem and even some fans that worked well on the A5 had rpm sense problems on the PA2s. The guys told me it was because of a dirty signal.
I am Intel of Borg. Resistance is futile. You will be assimilated.
i7 3930K @5Ghz - X79 ASUS Rampage IV Extreme - 4x SLI GTX580 - 16GB DDR3-2000 - 4x GTX 360 rads 24x CM fans - Aquaero 5 XT +6 PA2 Ultras - 2 x Enermax 1500W PSU - MM Extended Ascension Case - 2 x 452x2 Res and 4 x D5 - 3 x 24" Acer H243H LCD
Similar threads
